Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Thread: Advice on stuck/stripped bolts, and bleed screws
  1. #16
    Mansfield,MA
    You may want to purchase a left hand drill bit…..while you a’ byin’.
    Mod Squad
    2009 F800GS 1994 TW200
  2. #17
    I was thinking that.... but since I'll be drilling from the backside (I hope), I think I want a regular bit.
    Just ordered a set of these:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
  3. #18
    As usual for me, two steps forward, one step back.
    I was able to get the bolts out of the caliper, yay!
    Root cause? I'm an idiot... I was using a one-size-too-small driver.
    The one I stripped I was still able to pound it in and then get it extracted.
    Thanks for all your help!
  4. #19
    To put a pin on this thread:
    - The replacement bolts, and replacement caliper pin arrived.
    - The bolts I replaced, though they're okay with the correct torx bit (!) - I kept the old ones. I also put Never-Seize on them.
    - For the caliper pin that was stuck, I was able to drill it out a bit, and then pound in the next-size-up torx bit, and then was able to extract. I also put the new one in with some Never-Seize.
    thanks all!
  1. stripped oil pan bolts
    By brant914 in forum Airheads
    Last Post: 03-08-2018, 10:13 PM
  2. Stripped Screws
    By skibumwi in forum Wetheads
    Last Post: 04-10-2017, 11:30 PM
  3. Bolts, nuts, screws....
    By nelliott in forum Hexheads/Camheads
    Last Post: 03-25-2013, 11:36 PM
  4. Removal of stripped screws/bolts
    By wzellwzell@yahoo.com in forum Oilheads
    Last Post: 12-06-2010, 12:20 PM
  5. stripped windscreen screws '05 R1200RT
    By Harrington in forum Hexheads/Camheads
    Last Post: 10-07-2010, 09:14 PM
