Results 1 to 15 of 18
Thread: Replacement grips on newer R1250's
    May 2015
    Oregon
    Has anyone replaced the grips on a R1250 flavor BMW? I'm assuming they (RT, GS) are all the same.
    I was able to change them on my 2009 K1300GT by carefully cutting them off with a razor blade, but not sure if the grip is actually glued or bonded to the newer heated sleeves or not.
    I really like the Pro Grips over the stock grips on my 2021 R1250GS.
    Registered User Dann's Avatar
    Dec 2013
    Laval, QC, Canada
    Quote Originally Posted by brian_pnw View Post
    What is it you don't like about the grips?
    In my case, I always found them to be too small.
    I enlarged them on both my 07RT and on my19RT using fishing rod handle heat shrink tubing (I added 3 layers to get the size I wanted)
    YMMV
    Picture from my 07, same thing on the 19
    Daniel
    If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
    2019 R1250RT - 2007 R1200RT (186,000 km) - IBA # 56396
    Registered User brorke's Avatar
    Nov 2014
    Chesnee, SC
    Grip buddies for me on both my 1250RT and 1200 GSA https://www.originalbeemerbuddies.com/
    Bill Rorke #200394
    Chesnee, SC
    2019 R1250 RT
    2009 R1200 GSA
    Registered User lirider's Avatar
    Oct 2015
    LI, NY
    I've had these on my RT since new:
    Grip Puppies
    Also put them on my wife's CTX ... they really do the trick on giving the grips a larger diameter without any adverse effects on heating when it's cold out.
    2016 BMW R1200RT
    1996 Honda VF750C Magna
    1983 Honda CB550 Nighthawk
    Dec 2013
    Laval, QC, Canada
    I've used Grip Puppies on my bike before and I find the heat shrink tubing solution far superior. They are much more resistant . I had to change my grip puppies every two years and I never had to change the tubing.
    You can adjust the thickness as you like by adding layers, heat transfer from the grip is better, they don't get soaked in the rain. Easy to install and remove if needed.
    YMMV
    Daniel
    May 2015
    Oregon
    Specifically, has anyone ever REMOVED the grips on a newer R1250 BMW?
    I don't want to start cutting off the grips if they are permanently attached to the sleeve with the heating wire. The replacements are $175+ each side.
    My 2009 K1300GT was pretty easy to remove the stock grips.
    Thanks!
    Wills Point, TX
    Dec 2016
    Cartersville, Ga.
    Quote Originally Posted by Dann View Post
    YMMV
    Hi Daniel, what brand/style of fishing rod handle heat shrink are you using? A search of the WEB comes up with a lot of different brands and styles. I like the looks of the one you used.
    Thanks, Johnny
    Dec 2013
    Laval, QC, Canada
    Quote Originally Posted by dixierider View Post
    Thanks, Johnny
    I got them from Aliexpress
    https://www.aliexpress.com/snapshot/...11915350740209
    I think I used the 45mm and maybe 50 on the last layer but I ordered 40,45and 50 at the time to be sure.
    Daniel
    Debbie's Servant Lee's Avatar
    SW Iowa
    YMMV
    I'm surprised yours only lasted two years. The ones on our bikes are 5.5 years old and show no signs of wear or cracking. 56,000 miles on mine and 53,000 miles on Debbie's.
    Lee
    2016 R1200RS
    MOA # 30878
    Dec 2016
    Cartersville, Ga.
    Got it
    Thanks, Johnny
    I just installed 3 layers of 1.5" fishing rod heat shrink. I like the way they look vs the Grip Puppies. I have no idea about their longevity. I've used Grip Puppies and they seem to last a couple of years and look bad for the last year.
    Dec 2013
    Laval, QC, Canada
    Quote Originally Posted by dravnx View Post
    Had them for a couple of years on my last bike.(maybe 3 ) never had to replace them and they didn't show any wear. 2nd year on my 1250
    Daniel
    Aug 2018
    Fargo, ND
    Grip Puppies here too, and another pair will go back on when they need to be replaced.
    From the only real Fargo, ND!
    Lanark County near Ottawa ON
    We did what this guy did and really like the result. These last forever.
    https://advrider.com/f/threads/re-gr...p-wrap.925042/
  1. R1250 rsd ?
    By Dann in forum Wetheads
    Last Post: 12-26-2019, 07:32 PM
  2. R1250 and GS-911 Issues
    By roger 04 rt in forum Wetheads
    Last Post: 09-02-2019, 07:45 PM
  3. Replies: 15
    Last Post: 10-02-2013, 01:38 PM
  4. 2005 R1200GS replacement grips?
    By MasterChiefmas in forum Hexheads/Camheads
    Last Post: 10-03-2010, 08:45 PM
  5. Replacement grips
    By Picinisco in forum Oilheads
    Last Post: 05-02-2007, 05:41 PM
