Results 1 to 8 of 8
Thread: K1300 GT miss
    Jul 2016
    Port Matilda, PA
    K1300 GT miss
    I have a 2010 K1300 GT. It went into dealer to get new tires installed, running fine otherwise. After the tires were installed the bike has a bad miss. I can’t think of anything during a tire change that would lead to this but otherwise it’s the worlds biggest coincidence. Is there anything mechanic could have done to result in this? Plug wire, o2 sensor, something with the computer? The bike was literally running perfectly before and afterwards I felt lucky to make it home. I picked it up at closing with no other way home, otherwise I would have left it. I believe they may also have reset computer for a false headlight warning light.
    Left Coast Rider
    Check your wheel speed sensors, front and rear. Make sure they are properly spaced from the timing rings mounted on the wheels. Ensure the sensor wires are intact and unchafed.
    Jul 2016
    Port Matilda, PA
    Thanks, I hadnít thought of that. I heard the bike start up in the garage after the tires were mounted and it sounded fine. It was only when he drove it around the shop and they reset the faulty headlight warning that the miss developed.
    Left Coast Rider
    Quote Originally Posted by 49179 View Post
    If the miss occurs when the bike isn't moving there's a different issue. I wouldn't think that resetting the headlight warning would cause this problem, and the wheel sensors is a bit of a long shot on my part, but I'm curious to know what the eventual solution turns out to be.
    Well it all goes back to the question, " what was the last thing that was done to the bike before everything went to s**t?" Maybe someone operating the computer didn't know what they were doing and changed the wrong setting?
    Jul 2016
    Port Matilda, PA
    Itís possible that Iíve forgotten the #1 rule of diagnosing a problem - start simple. After languishing in the dealership for a month or so the best guess is a tank of bad gas. There are no fault codes or other obvious issues. The mechanic has occasionally taken it out and reports that itís much improved though not yet normal. Fortunately itís not my primary bike and only have about 2 hours of labor cost into it. Iím not totally convinced since in spite of having bought gas at some really sketchy places over the years, Iíve never actually had contaminated gas. The recommendation is to run a few tanks of gas at higher than normal revs. If thatís what it takes, Iím game!
    Left Coast Rider
    The recommendation is to run a few tanks of gas at higher than normal revs. If that’s what it takes, I’m game!
    The classic Italian Tune Up! Send video!
    Also, try putting some gas-line anti-freeze in your tank to disperse any water which may be in there. I think a product like Heet does the same thing. https://www.goldeagle.com/brands/heet/
    Nibley, UT USA
    Yes, the red bottle in case thereís water in the system. Beyond that I think the OP needs to find out from the dealer exactly what was ďresetĒ on the light erroróďclear codesĒ only, or were other adjustments performed. And what error codes is the bike showing now?
    Best,
    DeVern
    DGerber
    1983 R80ST ó 1984 R80 G/S-PD ó 2004 K1200GT w/Hannigan S/C ó 2010 K1300GT ó 2018 R1200GS
  1. K1200 vs K1300
    By RBEmerson in forum Wedge K-bikes
    Last Post: 01-06-2017, 11:52 AM
  2. Ohlins on K1300 S
    By suttie in forum Wedge K-bikes
    Last Post: 04-09-2012, 09:41 PM
  3. k1300 s and r
    By roadcrave in forum Wedge K-bikes
    Last Post: 04-03-2010, 01:05 PM
  4. air horn k1300 gt
    By EW1952 in forum Wedge K-bikes
    Last Post: 08-22-2009, 05:31 AM
  5. New K1300 GT
    By TIMRFO in forum Wedge K-bikes
    Last Post: 05-28-2009, 10:43 PM
