I just picked up a 2013 GS with 15k miles. After riding a bit, I have noticed that the point at which the clutch engages varies - it seems to be 2 positions. Position 1 (engine warm or cold, but first putting the bike in motion) is clutch lever 1/2 to 2/3 out. Position 2 (engine warm or cold, but anything after initial motion) is clutch lever only 1/4 out.
I've done some searching (here, adv-rider, and you tube), and this seems to be a characteristic of the early LC, wet clutch bikes (2013 and early production 2014s). Early diagnosis seemed to indicate the need to bleed the hydraulic clutch mechanism, but later on I have seen discussion of a design flaw in the transmission shaft that BMW corrected in later production units.
Is there a definitive cause and cure?
Roscoe
Middleton, ID
Roscoe
Middleton, ID
