Results 1 to 5 of 5
Thread: Hard to shift after drop.
    I was off-roading with my 2017 F 800 Gs today and dropped it. It bent the shift lever slightly into the case. Didnít dent of chip the case. But now itís shifting hard and neutral is hard to find. Any help will be greatly appreciated
    Mansfield,MA
    Quote Originally Posted by Scudrunner View Post
    Might be good to look at the ďexplodedĒ view on the parts breakdown. I did it on a Honda one time and the shifter rod- fork attached, came in from the other side of the bike.
    I can, for sure, recommend NOT trying to straightening the lever while attached unless you are very careful.
    Let us know how you make out.
    Good luck.
    Mod Squad
    2009 F800GS 1994 TW200
    We did bend it back but supported the base and shaft as it was just the tie peg portion of it. Itís shifting the same as before we bent it back. Thank you for the reply.
    Ended up something very simple. Cable adjustment. The big knurled lock nt had come loose letting the cable get loose adjusted and back in business.
    Mansfield,MA
    Always good to hear a follow up.
    Mod Squad
  1. Shift Lever Adjust with Shift Assist - How?
    By BeemerMike in forum Wedge K-bikes
    Last Post: 10-12-2018, 03:10 PM
  2. 1999 R1100RS hard shift from 2nd to 3rd
    By skotlyc in forum Oilheads
    Last Post: 05-29-2013, 09:23 PM
  3. Don't Drop the Bike
    By BCKRider in forum Just Ridin'
    Last Post: 01-07-2013, 01:15 AM
  4. 2011 GSA hard to shift
    By selyab in forum Hexheads/Camheads
    Last Post: 10-25-2011, 04:41 AM
  5. Sticky shift lever. Shift lever pivot seized
    By kim_cohan in forum Oilheads
    Last Post: 09-26-2010, 02:29 PM
