Results 1 to 8 of 8
Thread: Paddock spools? 2021 S1000XR
    Registered User pneumadeux's Avatar
    Jun 2021
    Cincinnati, Ohio
    Hi everyone,
    Now that I have my spankin' new 2021 XR in the garage, I'm doing the compulsory accessorizing.
    I have a set of Pit Bull stands (front and rear) that have served me well for other bikes, and is wide enough for my XR, but... the swingarm on my XR doesn't seem to sport spool holes.
    Am I missing something?
    Debbie's Servant Lee's Avatar
    SW Iowa
    Welcome to the forum.
    What about buying a centerstand?
    Centerstands are handy when away from home.
    Lee
    2016 R1200RS
    MOA # 30878
    Jun 2021
    Cincinnati, Ohio
    The bike does have a centerstand...
    Honestly, I've never used a centerstand before.
    But, when I have to have the front wheel off the ground, won't having a rearstand be more stable?
    Quote Originally Posted by pneumadeux View Post
    I would just use the center stand. If it is nose heavy when the front wheel is off (it probably won't be) I just use a small scissors jack to stabilize the front while on the center stand,
    SW Iowa
    I find using a front stand and centerstand very stable.
    With some front wheel stands you need to place a piece of plywood under the centerstand to make sure the rear tire does not touch the ground when lifting the front wheel.
    Give it a try. You may need to try different thicknesses of wood under the centerstand.
    I also set the suspension to one rider before lifting the front wheel.
    When lifting the front, watch the back tire to make sure it does not touch the ground.
    Lee
    2016 R1200RS
    MOA # 30878
    Mansfield,MA
    Nice garage
    Mod Squad
    2009 F800GS 1994 TW200
    Jun 2021
    Cincinnati, Ohio
    [QUOTE=Lee;1253215]I find using a front stand and centerstand very stable.
    What beautiful bikes... what a beautifully clean garage...
    Seeing your bikes on the center with the front wheels off certainly inspires confidence.
    Since I've never had one before, there's all the questions about safety, how far up the rear will be so I can do chain work or remove the wheel, etc.
    One more thing for me to experience as a new owner.
    Thank you!
    Same predicament here… but… I fitted the OE “M” chain adjuster and it has a GP style paddock stand hooks… probably going to retro bobbins instead of the hooks at a later date
  1. Replies: 3
    Last Post: 04-18-2021, 10:34 PM
  2. 2021 SQUARE ROUTE RALLY REGISTRATION OPEN June 4, 2021
    By Eap in forum Regional Northeast
    Last Post: 04-01-2021, 03:38 PM
  3. DynaMoto Paddock Stand Review
    By etiennelau in forum Gear
    Last Post: 10-31-2017, 04:21 PM
  4. removing front wheel without paddock stand or jack
    By droptine in forum Hexheads/Camheads
    Last Post: 02-29-2016, 02:39 PM
  5. Paddock Stand Q
    By Peter_Krynicki in forum Gear
    Last Post: 06-20-2008, 01:12 PM
