Results 1 to 7 of 7
Thread: A more reliable fuel pump?
    JohnWC
    Akron, Ohio
    91 k75s. I have had endless problems with the fuel system on this bike. I have now replaced everything in the tank, including a $280 fuel sender unit. The problem was that it kept blowing the fuel fuse. I have spent considerable time on this and have found the problem: the nearly new fuel pump locks up if the bike is not run for a period of time. (I realize this has never happened to anyone else, so we can skip that. I'm just lucky.) I won't go through all the testing, but believe me, the pump will do nothing but blow fuses, then, if I jump a 12 volt motorcycle battery directly to the pump, it will start up and run fine. I then reconnect the pump to the harness: it runs fine, no fuse blowing. The pump is the problem. It sticks just enough to keep it from turning. How this can happen, I have no idea. It's in filtered gas. It's a little motor with roller bearings in the bottom. I've had these apart, they're not that complicated.
    I bought the pump new from Euro Moto Electrics three years ago, and it has maybe 60 miles of run time, about 3 hours. This same issue has happened before with this pump. It is a 52mm Enduralast pump, $200 cost.
    I'll contact EuroMoto Electrics, but I already know what I'll hear: "We've never heard of that. We've sold hundreds of them."
    My question is, anyone know where I can buy a better pump, and preferably not a $400 BMW one? I would feel a bit stupid giving Euro Electrics another $200 for another quite possibly defective pump.
    Mansfield,MA
    You could try some Mystery Oil in the gasoline- as a bit of lube.
    You could circumvent the bikes original wires and go directly to the bikes battery and use this to check the wiring loom/harness.
    At the age of the bike, it would be easier to have wiring and connections go bad and have more resistance than the fuse/circuit was intended to handle.
    Mod Squad
    2009 F800GS 1994 TW200
    Apr 2020
    EAST BAY FL
    I put one of these in my k1100. So far so good. https://www.highflowfuel.com/quantum...s-16121461576/
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    More resistance in the wiring causes current to go down, and not blow a fuse.
    On the other hand, a stuck or stalled pump motor will cause the current to go up, and blow the fuse.
    Jan 2005
    Roanoke, VA
    Just an FYI, the fuel pump is before the filter. There is a Mustang fuel pump that fits but I don't know which one. Should be availible by many manufacturers.
    These pumps go for less than $30 on ebay:
    https://www.ebay.com/itm/15434215374...0AAOSwTIJfBCDE
    -Live as fully as you can as long as you can-
    Aug 2018
    Fargo, ND
    I agree these pumps are shared with other vehicles. i had a 2003 Yamaha R1 and needed a fuel pump. I found some info on the internet and went down to the local auto parts and bought one for a Honda automobile. It was and exact match, right down to the wiring harness connection. Plus it was $60 instead of $500.
    From the only real Fargo, ND!
  1. Critical - 2010 K13GT fuel pump and fuel level problems
    By capricorn54 in forum Wedge K-bikes
    Last Post: 05-09-2019, 08:10 PM
  2. Recall is on- fuel pump flange/fuel pump
    By David13 in forum Motorrad
    Last Post: 10-25-2018, 10:15 PM
  3. Replies: 5
    Last Post: 05-31-2014, 05:21 PM
  4. '85 K100RS Bad fuel pump or fuel pump relay?
    By 117336 in forum Flying Brick K-bikes
    Last Post: 11-07-2012, 04:29 PM
  5. '87 K75s Fuel Pump Filter Gauge Breather Hose Routing - Fuel Pump
    By kentuvman in forum Flying Brick K-bikes
    Last Post: 08-24-2011, 04:22 PM
