Results 16 to 17 of 17
Thread: Left Leg Amputated! Electric shifter??? 2011 RT HELP Please
    I found an online article from a Connecticut rider group about a man who lost his left leg to a car driverís left turn. Afterwards he had a Pingel shifter mounted on his BMW F800 GS. I checked, that bike has the CAN-BUS system, too. Just FYI for you all. Thanks for all the input. Still going to bounce my situation off the local dealershipís repair department.
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    Good to hear! But...
    The coil for a 2011 r1200RT is p/n 12 13 8 520 154 if you use the "straight" type,
    or p/n 12 13 8 520 173 (left) or 174 (right) if you use the angled type.
    The coil for an F800GS is either 12 13 8 523 968 for the earlier years except for the Adv version,
    and the coil for later years, and the May 2012 to March 2016 Advs is 12113 8 561 404.
    So that still leaves open the question of "will the trigger signal work?" Don't talk to the service manager, talk to a Master mechanic, or at least to a later "R" specialist, or even get persnickety with Pingel, to determine if there is a difference in what the computer sends to the primary side of the coil.
  1. Issue with 2011 R1200RT Electric Windshield
    By so_tx_rider in forum Hexheads/Camheads
    Last Post: 10-25-2013, 06:20 PM
  2. Replies: 0
    Last Post: 10-25-2013, 02:28 AM
  3. 2011 RT; Left front panel removal with radio?
    By mt65 in forum Hexheads/Camheads
    Last Post: 05-29-2012, 01:49 AM
  4. Shifter & Brake Lever Adjustment - 2011 R1200RT
    By hjuster1 in forum Hexheads/Camheads
    Last Post: 05-23-2012, 01:45 PM
  5. Add on Electric Shifter
    By miairhead in forum Gear
    Last Post: 08-31-2011, 02:10 PM
