Results 1 to 6 of 6
Thread: 2003 R1150RT Shuts off when turning the handlebars left
    As the title says my motorcycle started totally shutting off when I turn the handlebars to the left. It starts and runs fine but if I am maneuvering at slow speed and I turn the bars even a little bit to the left it shuts off. It doesn't even get power if I have the wheel locked to the left and I turn the key to the on position, I have to first straighten the wheel to get power.
    I have tried to find any loose connections without taking anything of the Tupperware off or see if there is an exposed wire and it is shorting out but I haven't found anything yet.
    Has anyone else ever heard of this? Or something like it?
    Left Coast Rider
    Nov 2011
    Apparently the wires leading from the ignition into the harness were zip-tied too tightly to the frame which eventually causes the wires to weaken and intermittently separate. Remove the zip ties, examine those wires and I suspect you will find your issue. Then, when reassembling, leave the zip ties loose.
    More technical data will follow from those in the know.
    Nov 2011
    Central Ohio
    With the engine running, wiggle the wires near each zip tie and you can probably pinpoint the break pretty quickly.
    Larry
    2006 R1200RT
    Cut the zip tie(s). Peel enough of the outer covering to find the individual wires. Wiggle the green wire and the red wire. It is likely a broken conductor in one of these two.
    Thanks everyone for the help. The green wire was cut all the way through. It is fixed and running great now.
    Mansfield,MA
    Quote Originally Posted by monstersdad96@gmail.com View Post
    Nice.
    Thanks for finishing up the thread.
    Mod Squad
    2009 F800GS 1994 TW200
  1. 2003 r1150rt left side foot peg
    By rhood1960 in forum Oilheads
    Last Post: 06-02-2012, 01:59 PM
  2. R1150RT w/ J&M 2003 CB
    By tmcmahan in forum Oilheads
    Last Post: 11-01-2008, 06:30 PM
  3. 04 R1150RT w/J&M 2003 CB
    Last Post: 08-18-2008, 02:02 AM
  4. Lower handlebars on R1150RT?
    By waltoliver in forum Oilheads
    Last Post: 07-21-2005, 05:40 PM
