Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Thread: Rear brake fluid reservoir cap question
  1. #16
    Registered User ezwicky's Avatar
    Oct 2012
    Richmond VA
    Should work with a file that small. I assume they are JPGs. You hang out of various forums, so this shouldn't be that difficult. It's really easy, though, so I'm scratching me head.
    You are trying to upload from your computer? Not sure how that would work on a smartphone...
    From my laptop. I do this all the time. Not here though. But I get the expected popups and dialog boxes, but nothing happens after I select a single file and "upload". Nothing. I'll reboot and try again.
    BMWMOA #182796
    '76 R90/6
    '80 R100RS restoration project
  2. #17
    Liaison 20774's Avatar
    Well, you certainly know how to do it...you did it back in 2013!
    https://forums.bmwmoa.org/showthread...l=1#post874844
  3. #18
    Oct 2012
    Richmond VA
    Seems to be working using FireFox.
    Not work with Chrome.
    'scuse my feet!
    BMWMOA #182796
    '76 R90/6
  4. #19
    Oct 2012
    Richmond VA
    Here's that bike now
    BMWMOA #182796
    '76 R90/6
  5. #20
    Registered User STEVENRANKIN's Avatar
    Spencerport, NY
    Micro fiche and things
    So, my quick look at a BMW microfiche shows no part number for the cap and float separate. The whole unit is #18, Cap and reservoir. Kind of looks like there never was a way to buy the individual internal parts such as the float. Further, the part 149 has been superseded and is NLA. The new part 961 does not show the float and likely it is to be used in the 81 and newer bikes. In 81, BMW removed the front brake master cylinder front under the gas tank placing it on the handle bar. At the same time, they removed as far as I know the brake level electrical system because any instrument cluster I have seen since then does not have a brake level warning light. The Brake level warning light was removed and the High beam light was moved from the tach to the center.
    Seems you found the reason for the float sticking and I hope you can fix it, I guess the only thing other than that is to look for a used one. Hope this makes sense. St.
  6. #21
    Jul 2004
    Charlottesville, VA
    The under-tank MC had the float system because the brake fluid level was not able to be checked with a normal visual inspection. When the MC went to the handlebar you could see the level and no longer needed the light. I'm not sure why the rear ever had a float; maybe just because BMW already had the warning system in place and couldn't resist the chance to extend its use. But if you can see the fluid level, you don't need the float.
    Anton Largiader 72724
    Tech articles - YouTube
  7. #22
    Oct 2012
    Richmond VA
    Thanks Anton, that makes sense. I'll just use it as-is, since it's sound in every other way.
    BMWMOA #182796
    '76 R90/6
  8. #23
    Spencerport, NY
    Who knows
    Anton, we will never know why BMW did things they did. My 78 RS has a rear master cylinder with the float and wiring tied into the warning light on the dash. Either the front or the rear low level will light the light.
    It was a short span of years they used a hydraulic rear brake with the float and switch. The early 77 RS bikes had drum rear brakes as did the /7 bikes, Then in 78 the RS went to disc, followed in 79 by the new RT. As for the 78 and newer /7 bikes and the S bikes it is fuzzy on when or if discs were used or drum. Oh, the S bikes used disc, not sure if drum was used all years of the /7 bikes.
    All I know is 80 and 81 was the cross over for changes in the bikes for brakes and ignition systems. Kurt and Snowbum, LOL keep better track of things than I do. St.
  9. #24
    Albuquerque, NM
    Quote Originally Posted by STEVENRANKIN View Post
    BMW was unique in having an under tank brake fluid reservoir and since you couldn't readily see the fluid level, they provided a fluid level warning capability. When they went to the handlebar reservoir, the fluid level was easily visible and no level warning was necessary. The rear level warning never was necessary, but the circuitry was there so they did it.
    BMW is massively safety conscious and since it is essentially a family owned company they are extra conservative regarding their liability. Motorcycles are "dangerous!"
    Kent Christensen
    21482
    '12 R1200RT, '02 R1100S
  1. Rear brake fluid reservoir
    By ccolwell in forum Wetheads
    Last Post: 01-04-2021, 03:23 PM
  2. Brake fluid reservoir pictures please
    By epirusgr in forum F-Twins
    Last Post: 05-16-2020, 12:45 AM
  3. 03 R1150R rear brake fluid reservoir location?
    By pacemaker in forum Oilheads
    Last Post: 07-23-2018, 11:40 PM
  4. Clutch and Brake Fluid Reservoir Cap Removal
    By BC1100S in forum Wedge K-bikes
    Last Post: 09-15-2017, 04:16 AM
  5. 1994 K75S ABS I Rear Brake Fluid Reservoir
    By Slipster in forum Flying Brick K-bikes
    Last Post: 03-02-2014, 08:29 PM
