Results 1 to 10 of 10
Thread: Specialty tools for 1200 vs. 1250
    Registered User captainmarko's Avatar
    Apr 2015
    Las Vegas, NV
    I am considering trading in my '15 RT for a GSA. I do my own maintenance and have the necessary BMW specialty tools. Are the TDC tool and the cam timing tool the same on the 1250 or would the new engine need new tools. I'm pretty comfortable with this engine, so if it does need new ones, maybe a lightly used '18 1200GSA would be the ticket?
    Answers?
    Opinions?
    Sleep in the trees and keep your knees in the breeze.
    Registered User LFarling's Avatar
    Oct 2016
    Harrisburg, PA
    Looks like it is gonna be expensive to say the least.
    Lee
    2017.5 R 1200 GSW
    Nibley, UT USA
    That H-D PanAmerica with it’s no-maintenance hydraulic lifters is looking better all the time….
    Best,
    DeVern
    DGerber
    Apr 2015
    Las Vegas, NV
    Quote Originally Posted by LFarling View Post
    LFarling...new cam timing tools?
    Oct 2016
    Harrisburg, PA
    Quote Originally Posted by captainmarko View Post
    Yes. Left and Right I think I saw they are 170 for the pair. Now If you want them I would order now as they may be or become rare fast!
    I am pretty sure the TDC and Cam Chain Tension are the same.
    Let me see if I can find the link.
    EDIT I looked the part number up and I can not find them available anywhere. I have included a link to the part number on a German site. It is 169.95 but then shipping is going to be a bit. If I was buying a 1250 I would order the tools from Germany and wait. It is going to be a wait. If you want to get a idea look at cam timing tools for BMW cars. II stumbled onto that and the kits look a lot like what we have for our bikes but less pcs.
    https://www.kfm-motorraeder.de/cms/e...id=83302467268
    Lee
    2017.5 R 1200 GSW
    Apr 2015
    Las Vegas, NV
    Great! Forewarned is forearmed.
    Thank you very much!
    I looked on the R1250RT Service DVD I got today and the main parts of the cam chain tensioner tool (lower 2 parts) are identical, HOWEVER the spacer ring is NOT the same - this will change how far in the tensioner goes and how much tension it loads the on the cam chain
    R1250 with VIN starting with WB10J63 (Order No. 83 30 0 444 282 )
    The 2016 R1200GSA I have uses the following (Order No. 83 30 2 339 885 ):
    So I would be VERY CAREFUL as using the 1200 tensioner's spacer sleeve looks like it's quite different in length from the R1250's
    I put the part numbers to order above so if you have the tools for a 1200 you only need the Camshaft alignment plates shown in a previous post and the new sleeve for the 1250
    Hope this helps.
    Dave
    Oct 2016
    Harrisburg, PA
    Quote Originally Posted by eplerd View Post
    Hope this helps.
    Dave
    AS I Said I was not sure as I have no interest. The ring can be made out of any copper or brass pipe once the dimension is known.
    It is the jigs themselves that are going to be unobtainable.
    It is good information the TDC tool and the Cam chain tensioner proper work.
    Boxflyer will be on it for that ring as soon as he gets a chance I am sure.
    Lee
    2017.5 R 1200 GSW
    I'm ordering the sleeve - can post here what the length is once I have it (give it a month or two)
    I was also told by Bob's BMW that they can get the cam phasing jigs - but it's gonna be spendy (still cheaper than one dealer valve adjustment)
    Anyone know if the shims are the same diameter as the R1200 motor's shims??
    BTW, I See your profile says Harrisburg, I grew up in Camp Hill and New Cumberland (in early 70's)...
    Dave
    Oct 2016
    Harrisburg, PA
    Dave
    How much for the jigs and any time frame?
    Like I said they list for 169.95 so I cant wait to see what the cost really is.
    Lee
    2017.5 R 1200 GSW
  1. 1250 RT Spare Key Fob
    By zip50 in forum Wetheads
    Last Post: 04-18-2021, 11:54 AM
  2. GS 1250 Adventure
    By manuallaborer in forum New Members
    Last Post: 06-02-2020, 04:08 AM
  3. BMW 1250 service dvd
    By 105258 in forum Wetheads
    Last Post: 04-08-2020, 08:14 AM
  4. 1250 RT forum
    By Wethead in forum Wetheads
    Last Post: 08-21-2019, 02:18 AM
