Results 1 to 6 of 6
Thread: R1250RT switched power
    May 2018
    Lincoln, MA
    The power from the USB lead in the right side keyed box is too low for modern phones, so I want to tap a switched lead up front to power my phone mount. Would run a lead to the battery, but don't want to inadvertently drain it. Anyone know where the best place is to get switched power? Or, is there a way to boost the power going to the USB lead in the right side keyed box?
    Jun 2015
    College Station, TX
    Quote Originally Posted by zip50 View Post
    Some newer phones allow faster charging with a higher-power charger, but they don't require that. The iPhone 12 Pro, for example, has the following power and charging specs.
    • MagSafe wireless charging up to 15 W
    • Qi wireless charging up to 7.5 W
    • Charging via USB to computer system or power adapter
    • Fast-charge capable: Up to 50% charge in around 30 minutes with 20 W adapter or higher (sold separately)
    Note that the fast charger is optional. The tiny 5 W charger is compatible with all iPhones back to the iPhone 5.
    You could check with your phone manufacturer to be sure.
    Ken
    2015 R1200GS
    Aug 2018
    Fargo, ND
    For any low amp draw power I needed on my 2018 RT I just tapped into the Powerlet wiring. I assume you still have a Powerlet just off the right side of the fuel tank?
    From the only real Fargo, ND!
    Registered User AjaxTheDog's Avatar
    Jun 2013
    Highlands Ranch, CO
    Blog Entries
    Quote Originally Posted by PoorUB View Post
    Ditto PoorUB's solution. That outlet is switched on and off automatically so your battery will be OK. The USB voltage converter you use (12v>5v) will also have an amperage rating on it. Probably less than the circuit can supply but worth checking to make sure so canbus doesn't shut it off should it exceed that with this an any other accessories you use it for.
    Bill in Highlands Ranch, Colorado
    2017 R1200RT
    2007 Eton Beemer Scooter
    May 2018
    Lincoln, MA
    Solution - higher USB power for Phone/GPS on R1200RT/R1250RT
    Thanks for the input everyone.
    Yes, kbowman, the phone is capable of charging at different voltages, but I found that using the BMW supplied USB socket in the right side storage compartment was too low when using the phone as a GPS.
    PoorUB and AjaxTheDog, that is the route I followed. The key for me was I did not want surface wires, so I bought one of these adapters that connects to the switched power plug you referenced inside the right side body panel. I now get full power to the phone through my Ram rig so it doesn’t lose juice if I am running multiple apps. Note that my Ram mount didn't have the USB adapter shown in that link, so I connected the pigtail to a LightningFast 3 amp USB adapter and then ran a line to my phone charger. Glad to provide further intel if needed. Will provide pix later.
    Registered User YeehaStephen's Avatar
    Deep in the Heart of Texas
    Power with a time-out I did this....
    Yeeha! Stephen
    R1200RS, R1250RT
    "Why eat a Burger when you can have Pie?!" Miss Vicki @ Lost Maples Cafe - Utopia Texas
  1. switched power source
    By miles2ride in forum Wedge K-bikes
    Last Post: 04-05-2021, 11:13 PM
  2. 12V+ switched power
    By romoto in forum Thumpers - F & G bikes
    Last Post: 06-09-2020, 04:05 PM
  3. Switched on Power
    By boogerman in forum Wetheads
    Last Post: 01-17-2019, 04:41 PM
  4. K75 and switched power
    By PAULBACH in forum Flying Brick K-bikes
    Last Post: 10-06-2008, 02:39 PM
  5. Switched power?
    By REBECCAV in forum Oilheads
    Last Post: 04-12-2007, 01:23 PM
