Results 1 to 7 of 7
Thread: Broken K75S OEM Corbin Seat Pan Repair
    Need assistance/suggestions for fixing the seat pan of my OEM Corbin seat. Specifically the rear hinge mounting point. The plastic that holds the retaining but cracked and now the seat is not connected at the team most point.
    Do you have a stock seat with the metal pan available? Years ago I took a Corbin, drilled out all the rivets and mounted the pad and cover on a standard metal K100/75 seat pan. Still got it.
    If you can't do it yourself, an upholstery shop can.
    Frank
    '17 R1200RS, '03 R1100S BCR#6/200, '85 K100/1100RS, '16 R1200RS (gone) '11 R1200RT (gone) '05 R1200ST (gone) '99 R1100S (gone) '96 Ducati 900SS/SP (gone) '92 K100RS (gone) 500,000+ BMW miles
    Quote Originally Posted by 51797 View Post
    Frank
    Frank,
    You might want to go out and check that "stock" seat pan. Stock early Kbike pans were an ABS type of plastic just like the OP's. Some of the early Corbin pans were fiberglass. I have never seen a metal early K pan in the hundreds that I have seen.
    Can you post photos?
    You are correct, Lee. Memory failing me as the years pile up. It was/is a plastic seat pan and in my opinion, superior to Corbin's fiberglass pan.
    Frank
    While Corbin, the seatpan is the OEM plastic version, not the Corbin fiberglass version. Hoping to find a solution that does not require a complete reuphostery at this point. Planning to do so in the future once I've landing on the desired seat upgrades (reshaping, etc.).
    Registered User 6322's Avatar
    Mar 2012
    Riggins, ID
    You might be able to use a piece of sheet metal to form over the damaged portion and hold it in place with a couple of rivets.
    Gary Phillips - #6322
    Wildland Firefighter, Retired, Riggins, ID
    Heartland Moto Locos BMW Riders
    '77 R100/7 Dirt Hack, '83 R80ST, '85 K100RS w/EML, '93 K1100LT, '00 R1100RS
    Thanks. Trying to work out a solution now. Will update when resolved.
  1. How to repair broken trim piece on side bag
    By mark1rob in forum Motorrad
    Last Post: 03-25-2021, 03:39 PM
  2. How to fix/repair a broken valve cover boss
    By tiffan2 in forum Oilheads
    Last Post: 07-23-2011, 11:56 PM
  3. Corbin Low Seat on a 1987 K75S?
    By mieczkow in forum Flying Brick K-bikes
    Last Post: 12-15-2006, 11:13 PM
  4. Corbin Seat on K75S
    Last Post: 06-20-2006, 01:31 AM
  5. Replies: 11
    Last Post: 06-13-2005, 03:44 PM
