Results 1 to 8 of 8
Thread: R1150GS Won't Run
    Liaison 20774's Avatar
    R1150GS Won't Run
    I got a PM from a member who needed help getting something posted. So here's what he sent to me:
    Quote Originally Posted by 37857
    2003 R1150GS will not crank and run. New fuel pump, new fuel filter, new injectors, new coil. Good spark, good spray pattern on cardboard test for both injectors.
    Please, does anyone have any idea what would be causing this? Was running good till fuel pump died?
    JC Blades
    Fuel lines?
    Did the in line get switched with the out line? Make sure the high idle cables are properly seated especially the right side. Go back and check all the work you did and all the places you visited on the bike. Lastly did the the old fuel pump quite working or did the bike die due to something else and someone assumed it was the fuel pump?
    Registered User dieselyoda's Avatar
    Mar 2013
    Winnipeg, MB, Canada
    I'm missing something: "will not crank and run".
    If it doesn't crank, wouldn't that be the place to start?
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    The major civilizing force in the world is not religion, it is sex.
    Jul 2004
    Charlottesville, VA
    That's why I stay out of secondhand diagnosis. WAY too hard to work out the details.
    Quote Originally Posted by dieselyoda View Post
    Anton Largiader 72724
    Tech articles - YouTube
    May 2021
    Amite, Louisiana
    The fuel lines are correct , won't go but one way they are male and female. Did not touch the throttle cables, there's only one on each throttle body and they come to rest on the adjustable stop screw. they both together when working the throttle. Not familiar with a high idle cable? I was very careful and didn't touch any other part enough to keep it from performing. I'm 81 yrs old and don't much anymore the bike's been sitting uo I usually crank it once a month and let warm up to normal temp. I knew the fuel pump was out turned the key on and it didn't run up to pressure. So I replaced the pump and removed all the old gas, cleaned everything best I could installed new fuel filter flushed fuel lines with new gas from tank to where they connect to injectors. Starter is working good sure don't want to burn it up trying to crank. After it sits awhile it'll usually fire when if first turns over, then the starter just grinds. Nothing. Darndest thing I've ever had happened working on a bike?
    Thanks for your reply.
    JC Blades
    May 2021
    Amite, Louisiana
    I should have said will not start. Starter working fine just don't want to burnt up.
    JC Blades
    May 2021
    Amite, Louisiana
    I should have said will not start. Starter works fine.
    JC Blades
    Mansfield,MA
    Welcome to the forum JC!
    It's a great place to find help.
    Gary
    Mod Squad
    2009 F800GS 1994 TW200
  1. R1150GS add ons
    By 2slowwheels in forum Oilheads
    Last Post: 03-26-2011, 04:37 PM
  2. Getting Rid of ABS on an '02 R1150GS?
    By JimMoore in forum Oilheads
    Last Post: 01-29-2010, 05:10 PM
  3. R1150gs
    By Picinisco in forum Oilheads
    Last Post: 12-06-2008, 02:48 AM
  4. K75 or R1150GS
    By lostandwandering in forum Oilheads
    Last Post: 12-03-2008, 12:28 AM
  5. R1150gs
    By ratiron in forum Oilheads
    Last Post: 05-04-2005, 12:34 AM
