Results 1 to 15 of 16
Thread: 2001 R1100R Broken weld at muffler bracket
    Sep 2020
    Charlotte, NC
    My R1100R muffler bracket broke off at the weld and needs repair. Received some advice and know i could try JB weld and if that doesn’t work then it would need to be welded and isn’t a major job. I called the local dealer and they don’t do any type of welding. So, I reached out to a few local MC mechanics and no one seems to be eager or able to weld the bracket back onto the frame. Anyone experienced this type of issue and if so is there an alternative solution to welding.... like a bracket that will attach to the frame without welding?
    2001 R1100RL
    Mansfield,MA
    Looks like there are a lot of welding shops in your area- give one a call. I don’t think this is a JB fix.
    Residual JB will make a real weld more difficult.
    Mod Squad
    2009 F800GS 1994 TW200
    A few years ago, my Staintune muffler cracked, at the inlet pipe, to the actual muffler. Aside from being surprised, as Staintunes seem to last forever, I found a welding shop that specialized in stainless metal fabrication. Didnít take long, and IIRC, was about $40.
    2000 R1100 RS
    2009 Jaguar XK
    Question: Is the break on the exhaust system? Or is the break on the bike frame?
    It matters because welding the exhaust system removed from the bike is one thing but welding on the bike frame is quite another because of the care required to not damage any of the bike's electronic components.
    Sep 2020
    Charlotte, NC
    Paul, the break occurred on the bracket which was part of the frame. A portion of the bracket is still connected to the frame.
    2001 R1100RL
    Gerard jagarra's Avatar
    Aug 2016
    Reno, NV
    Looks like 2 choices, either have a welder with a portable come to you to TIG weld it or go to a shop where they can do this method. In either case I would have the harness disconnected from your CPU and the battery disconnected. If it was me I would pull the CPU from the bike. The computer processor is located in front of the ABS brake unit located under the tank on the top tube, has a large connector on it.
    1994 R1100RS-(5/93)-,1974 R90/6 built 9/73,--1964 Triumph T100--1986 Honda XL600R
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    Unplug both the Motronic and the ABS pump multipin connectors.
    Ground the frame as close to the weld area as possible
    This will likely require removing the paint from that spot.
    Ufda happens..........
    Curmudgeon nrpetersen's Avatar
    Sep 2004
    minnetonka mn
    You might try to see if there is an aircraft welder specialist in your area that can do it with a gas weld rig. There were a lot of gals during and after WW2 that did magnificent work.
    Retired w 2005 K1200LT, 2000 R1100RT, & 1975 R90/6
    Left Coast Rider
    Nov 2011
    Quote Originally Posted by nrpetersen View Post
    They may have retired by now.
    Jul 2004
    Charlottesville, VA
    Charlotte is absolutely going to have welders that can do this. As mentioned, unplug the computers first.
    Anton Largiader 72724
    Tech articles - YouTube
    Sep 2020
    Charlotte, NC
    Appreciate all the information provided. I went with JB Weld and a metal strap which was used to secure the broken off portion of the bracket by pulling it back towards the tubular frame. So far everything is holding up fine.
    2001 R1100RL
    Left Coast Rider
    Nov 2011
    Quote Originally Posted by eleven View Post
    Pictures?
    Mansfield,MA
    I be interesting to see if it works out. Too bad you are so far from me. Ten minutes with the mig welder- good to go.
    Mod Squad
    Feb 2008
    Yes, really too bad.
  1. 2004 r1150rtp broken windshield bracket
    By Bcmcmoose in forum Oilheads
    Last Post: 10-25-2015, 11:35 PM
  2. Muffler Bracket
    By WREALINI in forum Oilheads
    Last Post: 06-27-2011, 02:14 PM
  3. Broken saddlebag aluminum latch bracket
    By brrider in forum Oilheads
    Last Post: 12-14-2007, 03:24 PM
  4. Broken muffler hanger on 04 R1150RT
    By kioolt in forum Oilheads
    Last Post: 09-14-2005, 12:05 AM
  5. Lowering Muffler R1100R
    By rpatrickmc in forum Oilheads
    Last Post: 09-23-2004, 08:39 PM
