Results 1 to 7 of 7
Thread: 2020 R1250R front axle seeping
    The Big Red One sgtbill's Avatar
    Jul 2006
    Columbus, IN
    I'm not sure whether it is lubricant escaping from a bearing or perhaps another oil. The forks are "upside down" so I guess there may be fork oil in this area? Anyone else see this kind of seepage?R1250R front axle.jpeg
    sgtbill
    Duty First!
    86 K100RS EML & 79 R100S & 83 R80ST
    2014 F700GS & 2020 R Nine T /5 & 2020 R1250R
    Registered User AjaxTheDog's Avatar
    Jun 2013
    Highlands Ranch, CO
    Blog Entries
    Probably just an overzealous greasing of the axle shaft as there are no bearings in the fork, they are in the wheel. This shaft does not turn, but I believe you are supposed to moly grease it when removing/installing the front wheel. If you had your tire changed recently that would explain it. Clean it off and see if it comes back. My guess would be it won't to any large degree.
    Bill in Highlands Ranch, Colorado
    2017 R1200RT
    2007 Eton Beemer Scooter
    May 2016
    RI
    Same
    I've got a 2020 R1250R I got last fall and had that accumulation but after cleaning it off it hasn't returned. Purely an over lubed axle sliding in and not evidence of a moving part. losing lube.
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Quote Originally Posted by AjaxTheDog View Post
    I agree.
    Sometimes I see this after I do a tire change.
    Lee
    2016 R1200RS
    MOA # 30878
    Jul 2006
    Columbus, IN
    Thanks all for the quick responses. I'll take a shop rag to it and keep an eye on it.
    sgtbill
    Duty First!
    Old Rider - OK Mechanic 105258's Avatar
    Mar 2004
    Teulon Manitoba Canada
    Axle Greese
    Quote Originally Posted by sgtbill View Post
    This is normal and is axle grease. It will not cause any harm to leave it there. I usually use a waterproof grease on the axle and spacer before installing it. I also press from of the same grease into the area between the seal and the bearing. This will help keep water and dirt from getting to the bearing seal. After tightening up the axle nut there is always a blob of grease around the bearing seal. I leave it right where it is. It will help to keep the junk away from the bearings.
    David Nicholls
    Teulon Manitoba - Canada
    2015 R1200GSA-LC
    Jul 2006
    Columbus, IN
    Quote Originally Posted by 105258 View Post
    Thanks for this information. If I see the grease seep again I'll let it stay there as added barrier to dusty dust and dirty dirt.
    sgtbill
    Duty First!
  1. Replies: 17
    Last Post: 02-23-2021, 09:24 AM
  2. R1250R 2020 Windshield protection
    By R1200gsa16 in forum Wetheads
    Last Post: 02-08-2021, 04:36 AM
  3. 2020 R1250R Low Beam Bulb Replacement
    By Josh in forum Wetheads
    Last Post: 10-14-2020, 11:04 AM
  4. Replies: 16
    Last Post: 08-24-2020, 11:58 PM
  5. 2019 v 2020 R1250R
    By ccolwell in forum Wetheads
    Last Post: 10-24-2019, 04:11 AM
