Results 1 to 6 of 6
Thread: 2017 1200 GSA Pro mode chip
    Watch This!!! junkjohn's Avatar
    Feb 2010
    Cape Cod, MA
    My bike came with the Enduro Pro chip under the seat. I'm just trying to figure it out. Can you leave it plugged in all the time in say rain mode or only for off road use? I looked in my manual but I still had this question. And any input on the function of this chip in the real world would be appreciated. Thanks in advance.
    John Simonds
    2017 R 1200 GS Adventure
    1975 Norton Commando 850 Roadster Mk 3
    If it ain't broke, fix it 'till it is.
    Registered User LFarling's Avatar
    Oct 2016
    Harrisburg, PA
    You leave it plugged in. It does nothing until you select that riding mode.
    RTFM If you look in your owners manual it will explain all this. Better then we can type it as there are pictures
    Lee
    2017.5 R 1200 GSW
    Feb 2010
    Cape Cod, MA
    I read the manual, but still was not sure about leaving it in. I also started over thinking it because the dealer did not have it installed, or even mention it being there.
    John Simonds
    Registered User marcopolo's Avatar
    Feb 2005
    Alexandria Virginia/Ottawa, Canada
    As said above, just plug it in, and leave it. It simply makes available Enduro Pro mode, as you scroll through the available ride modes. If you want Enduro Pro mode, select it. If you want Road mode, for instance, select that.
    Mark
    2015 R 1200 GS Adventure
    Registered User RIDERR1150GSADV's Avatar
    Apr 2017
    S.Florida
    I plugged the little gizmo (it is a wire hidden in a plastic doodad) in the bike when I got it and has been there the last 30K miles. As stated before, it doesn't do anything until the appropriate mode is selected. Those modes btw can also be customized further if you like.
    MOA # 108516
    Current ride 2018 R1200 GSA Triple Black
    Past rides '04 R1150RT, '05 K1200LT, '06 R1150GSA, 17 R1200RT
    Feb 2010
    Cape Cod, MA
    Thank you all for responding. Mine also has the cluster with Tach. and Speedo. not the newer style.
    John Simonds
  1. 2017 1200 GSA High Idle, Engine light ?
    By junkjohn in forum Wetheads
    Last Post: 08-09-2019, 11:34 AM
  2. 2017 1200 rt headlight
    By bullet in forum Wetheads
    Last Post: 12-10-2018, 04:03 AM
  3. 2017 1200 rt lc road noise
    By saslade in forum Wetheads
    Last Post: 06-14-2018, 10:35 PM
  4. Replies: 4
    Last Post: 06-01-2018, 09:41 PM
  5. Replies: 4
    Last Post: 09-23-2008, 05:05 PM
