Results 1 to 3 of 3
Thread: Sena 50R/Sena 30K Mesh Connections? Possible?
    Sep 2015
    Birmingham, AL
    Has anyone successfully connected their 50R with a 30K? If so, what steps did you take? Both units are running the latest firmware.
    J Goertz
    BMW MOAL
    2015 BMW R1200RT
    2012 Triumph Bonneville SE
    Sep 2015
    Birmingham, AL
    A couple of evenings ago I sent a request for help to the Sena Support desk. Today I received this reply:
    Hi Jack,
    Good day!
    All Sena Devices are compatible with each other either via Bluetooth or Mesh connection.
    To pair a Sena 30K with the Sena 50R via Mesh, turn on the headsets and tap the Mesh button once and it will automatically connect with Open Mesh, Channel 1.
    Note: the Sena 30K should be running on the latest firmware version 3.1.1 to make it compatible with Mesh2.0
    I hope this can help.
    Sincerely,
    Yobonne
    Technical Support Dept.
    www.sena.com
    www.buysena.com
    We're checking the firmware version on the 30K and then we'll try again. Looks like it should work, and very simply!
    J Goertz
    BMW MOAL
    2015 BMW R1200RT
    Registered User patm's Avatar
    Mar 2016
    Montreal, QC
    If both 50R and 30K have the latest software, mesh communication should work fine in public mesh.
    The group I ride with has a mix of 30K and 50S and we have no issues in mesh mode.
    Steps are easy, turn on your Sena, activate mesh mode. That's it!
    The mesh mode button is right there on top, behind the antenna.
    Pat
    Ride Safe!
    '16 RT
  1. Trouble pairing Sena 10OU to Sena SMH5-UNIV
    By glenfiddich in forum Gear
    Last Post: 06-05-2020, 12:30 PM
  2. Sena 20s EVO
    By RPGR90s in forum Gear
    Last Post: 04-05-2019, 01:30 PM
  3. Sena 20S
    By GlobalRider in forum Gear
    Last Post: 05-02-2017, 02:29 AM
  4. N-Com vs Sena
    By hesterx6 in forum Gear
    Last Post: 04-30-2017, 10:39 PM
  5. Sena 10s vs 10r
    By eric27 in forum Gear
    Last Post: 06-14-2016, 01:52 PM
