Results 16 to 18 of 18
Thread: Senior Moment: Brake Bleeding
    Left Coast Rider
    My personal opinion is that leaving the cap off one's brake fluid reservoir for any length of time is a bad idea.
    Even with the cap on, air will work its way to the top...or not. Leaving the cap off only invites water into the system - especially if your bike is in a humid environment.
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    GRIACG, the purpose in leaving the
    cover off was allow any air in the lines to flow upwards and I did get a number of air bubbles when I pumped the brake lever. There was more resistance this morning than last night. The final couple d'etat at removing the air was obviously taking the bike off the centre stand. If I should ever be unfortunate to have this issue again, bumping the off the centre stand will my first step to dislodge any stubborn air.
    I am not too concerned about a bit of moisture in the K's braking system as I alternate which bike gets ridden the most in a season. This year is the R's turn for the majority of rides and with a COVID summer in Ontario, I am unfortunately looking at only day trips for the second summer in a row. 😠👎
    The reservoir cap does not need to be off when holding the brake lever/pedal. The volume of fluids and gas does not change inside the system, it just swaps places.
    Kevin Huddy
    Silver City, Montana
    MOA# 24,790 Ambassador
    RK Ryder
    London, Ontario
    Quote Originally Posted by akbeemer View Post
    With regard to humidity, our cool spring has yet to experience any. My garage this spring has had a constant temperature of 60F.
    However, rather than risk damage to the braking system, I will bleed the K's front brakes next week before riding it.
    Thank you bring this to my attention. 👍
    Paul
    Paul F. Ruffell
    Knights of the Roundel #333
  1. Bleeding brake on R90/6
    By jcofwmburg in forum Airheads
    Last Post: 05-05-2014, 05:58 PM
  2. Brake bleeding
    By iwrench2 in forum Flying Brick K-bikes
    Last Post: 03-30-2010, 10:08 PM
  3. Brake bleeding help.
    By squiffynimrod in forum Airheads
    Last Post: 06-23-2009, 12:24 PM
  4. Help with brake bleeding!!!
    By mgordon in forum Oilheads
    Last Post: 01-27-2007, 06:33 PM
  5. ABS Brake Bleeding ???
    By warthog in forum Flying Brick K-bikes
    Last Post: 05-03-2006, 01:52 AM
