Results 1 to 8 of 8
Thread: 2012 RT DWS (Anti-Theft Alarm) Question
    Sep 2014
    Central NC
    After more than a year of ownership I'm getting around to playing with the DWS (Pkg 603). It's operation is covered in a separate manual from the Riders Manual and I've had no luck sourcing one. No luck finding info on it's operation... just battery replacement.
    I've tried to leverage from my '12 K16 GT manual but the systems are different.
    I get two beeps, two turn signal flashes and the indicator on the dash after hitting the left button once. Three beeps, three flashes and the dash light after two pushes. Right button cancels the dash light with a single beep and flash. That's it...
    I don't get a motion detector alarm when the bike is moved nor have I figured out a way to activate it without the remote.
    Is that all there is?
    Aug 2014
    Lakeland,FL
    Sent you a PM
    Sep 2014
    Central NC
    Question answered... thanks mikegalbicka.
    Aug 2014
    Lakeland,FL
    Glad I could help.
    Liaison 20774's Avatar
    So what was the problem? And how was it solved? Any advice for others??
    Aug 2014
    Lakeland,FL
    I sent him a pdf of the instruction manual for the DWA6 alarm on my 07RT
    Sep 2014
    Central NC
    In a nutshell:
    I get two beeps, two turn signal flashes and the indicator on the dash after hitting the left button once - This means the system has been activated. 15 seconds later the alarm will sound if the motion detector is tripped, if there is an attempt to start the bike without the proper key or disconnecting the alarm itself.
    Three beeps, three flashes and the dash light after two pushes - This activates the system as above only the motion detector is inoperative... handy for ferry boat, Eurotunnel transport.
    Right button cancels the system with a single beep and flash.
    More involved programing enables automatically activating the system when the key is turned off, turn off the lights/beeps and change the alarm sound.
    Thanks again Mike.
    Thanks for the basic update...I think that helps a lot!
  1. Anti-theft alarm
    By temesvar in forum Motorrad
    Last Post: 12-01-2016, 01:53 PM
  2. Replies: 0
    Last Post: 05-04-2015, 01:06 PM
  3. '13 R1200RT Anti-Theft Alarm??
    By dave in forum Hexheads/Camheads
    Last Post: 04-09-2014, 12:29 PM
  4. Disable Anti-theft alarm system?
    By R1100RT in forum Flying Brick K-bikes
    Last Post: 06-15-2009, 12:21 PM
