Results 1 to 13 of 13
Thread: sticking brakes
    Registered User brianfisk's Avatar
    Cromwell CT
    sticking brakes
    Hi all, 1998 R1100RT front brakes are sticking and I cannot seem to get them to to let go all the way. Just rebuilt the M/C. I have had stainless lines for awhile. Brake fluid is clean and I cleaned the calipers (letting the pucks out and cleaning them. They seem to push back in okay).
    Brakes drag more than I like. Any thoughts from the group?
    Brian
    Jul 2018
    Corralitos, CA - Santa Cruz County
    I eventually rebuilt my calipers with new cups and seals to make this problem go away on my 99 RT.
    Signature
    Sep 2014
    Central NC
    My first guess, since you rebuilt the MC, is somehow the compensating port may not be allowing pressure to bleed off.
    Check out this explanation of how it all works.... one of the best I've seen.
    http://www.st-riders.net/index.php?topic=11931.0
    Sep 2006
    CENTEX USA
    Level of fluid in m/c?
    I’ll fix the title in a bit...unless you meant it
    Steve Henson-Mod Team and past prez SABMWRA
    Registered User dieselyoda's Avatar
    Mar 2013
    Winnipeg, MB, Canada
    Check your grub screw adjustment.
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    “The major civilizing force in the world is not religion, it is sex.”
    Jul 2004
    Charlottesville, VA
    If your pads are old, and specifically if they have been in the bike for a long period of disuse, they are the problem. Replace them. I can't explain it authoritatively but I have some theories, not going into them, just replace the pads if they are old. Wear doesn't matter. Old.
    Anton Largiader 72724
    Tech articles - YouTube
    Cromwell CT
    brakes
    I should have added that the brakes were sticking before I did any work to them. I will check the grub screw as I did not play with it when I did the rebuild. Brake. pads are fairly new
    Left Coast Rider
    Nov 2011
    Quote Originally Posted by brianfisk View Post
    In that case, refer to Post #2. And replace the pads while you're at it.
    Cromwell CT
    fix?
    Well I tried to do the grub screw, was tearing it apart after using a solder iron to try and loosen it up. No good!
    took the front wheel off just to check (again ) that the bearings were okay, they were. I put it back together and pumped the brakes back up. I think that might have loosen the calipers up as it no longer is sticking as bad did a short ride and really hit the brakes hard, still seemed okay. will ride a longer distance soon and check again.
    thanks for the replies, Brian
    Sometimes removing the wheel and disk, and then spreading the pads fully will cause pistons that seem to be sticking to again be normal. In typical use the movement of the pistons is minimal - retraction is very slight. Retracting the pistons fully seems to correct sticking.
    Did you clean both tiny little holes ?
    There are two (2) little tiny holes leading from the reservoir to the piston chamber. One is the feed to the piston and the other smaller one is the return. If the return is restricted or blocked completely your caliper pucks will be slow to retract or stay stuck out and cause the problem you are describing.
    Sep 2014
    Central NC
    Quote Originally Posted by 69zeff65 View Post
    Read post #3
    Cromwell CT
    clean
    I did clean the holes. I think Paul's suggestion that I spread the pads did the trick ( I had done it when I cleaned the surface of the calipers a couple of times, I thinking I just needed to do it one more time)
    Brian
  1. Replies: 11
    Last Post: 06-01-2016, 12:47 PM
  2. Throttle sticking?
    By DNORDINKGT in forum Wedge K-bikes
    Last Post: 03-04-2013, 10:10 PM
  3. Sticking throttle
    By woody99 in forum Oilheads
    Last Post: 07-28-2009, 01:31 AM
  4. Sticking Throttle on RT
    By dpmonk in forum Oilheads
    Last Post: 09-16-2005, 11:33 PM
