Results 1 to 8 of 8
Thread: Clutch adjustment on K1600 bagger
    Iíve had a 2018 K1600 bagger for 37,000 miles and I am noticing a change in clutch engagement. When new engagement seemed to be pretty close to the handgrip, now it is almost at the end of lever movement. It never slips but I am wondering if the clutch pack is wearing out. If this bike had a clutch cable it would be a simple matter to restore it to the original release point. I use the quick shifter for both up and down shifting all the time. Anyone have experience with this?
    Aug 2018
    Fargo, ND
    No Adjustment. Have you tried to bleed the hydraulic clutch?
    From the only real Fargo, ND!
    Since it has gone from needing a lot of lever movement to release the clutch to very little lever movement to release the clutch, that tells me that the clutch has in fact worn "thin". I would think that air in the system would cause exactly the opposite result; ie, more lever travel.
    Sep 2014
    Central NC
    Is the clutch wearing out? Technically yes. Is it worn out? If it's not slipping and works smoothly...I would say no.
    Clutch engagement at the end of handle travel seems a common experience (complaint)... there are threads out there discussing tweaking the one adjustment between the handle and master cylinder. Do a search however I would not recommend messing with it.
    With use from new or after a flush/bleed fluid is able take up minute amounts of slack in the system with every clutch release (by design) and over time that results in the engagement point ending up where it is. That being the point where the slave cylinder piston is pushed back to by the clutch springs.
    I found changing out the mineral oil in the clutch circuit made a huge difference in feel (better seal lubrication) on my 2012. That was 10 year old oil... probably won't make as big a difference on your '18 but is something to consider.
    ebullient!
    Apr 2018
    Canterbury NH
    The friction zone on the B does move, especially at slow speeds. Mine does.
    Sep 2014
    Central NC
    With slight pressure on the handle I can feel the effect of the slipper clutch ramps as I gently roll on and off the throttle... kinda cool. However the engagement remains primarily at the end of handle travel. Didn't like it at first but have gotten used to it.
    ebullient!
    Apr 2018
    Canterbury NH
    Before I have my tune installed, I had a real problem with this friction zone; it seemed almost binary. For slow-speed work, I put the bike into second and use the rear brake more than I would normally. I now use the friction zone exiting a steep curve, but rarely other times.
    Sep 2014
    Central NC
    I know I'm repeating myself as I've mentioned it several times in a number of forums. I'd say 80% of my shifting issues on this bike went away after the mineral oil change. I'm thinking the old oil was causing a delay in the slave and I just could not get the timing right.... maybe because I ride other bikes as well. Between the oil, preload (which we've discussed) and simply miles ridden I'm shifting smoothly from about 1500 rpm up. No complaints. Although I will say, I remain a dry clutch guy, just prefer it (rare, I know).
  1. Clutch adjustment tip
    By r80r100rt in forum Airheads
    Last Post: 03-30-2015, 11:54 PM
  2. Clutch Adjustment
    By Rundel in forum Oilheads
    Last Post: 10-17-2012, 02:14 PM
  3. Clutch Adjustment
    By TGEORGE143784 in forum Airheads
    Last Post: 07-07-2011, 09:28 PM
  4. Clutch Adjustment ?
    By i2lguy in forum Oilheads
    Last Post: 08-15-2007, 03:05 PM
  5. Clutch Adjustment
    By KALTZG in forum Oilheads
    Last Post: 09-02-2004, 08:31 PM
