What I did to shorten the side and center stands-
Remove stand from bike.
Scribe a line down the center of the tube(s) to assist with later re-alignment.
Pick a convenient spot to take a section out using a pipe cutter.
Once the section is removed you will find the pipe cutter has “collapsed” the interior diameter a bit.
Find a piece of rod or solid section of bolt and use it to rejoin the sections. There will be adjustability due to the pipe cutters action.
Reference the scribed line for alignment.
Weld the area where the two pieces of the stand(s) touch being careful to have the rod or bolt centered on the “new” joint.
The first weld pass will easily pass through where the pipe cutter did its work fusing all three pieces together.
Finish to suit- paint etc.
