Results 1 to 7 of 7
Thread: 1997 f650 funduro- New rear brake line question
    CAL0987
    Oct 2010
    Pahrump NV
    Just got my new GALFER BRAIDED STAINLESS STEEL rear brake line.
    While starting to install, noticed that the stock line is attached to the Master Cylinder by a 6" thin metal pipe and the hose is clamped to that.
    With the new SS hose with 2 Banjo bolts, one on each end, do I remove the metal pipe and connect the hose directly to the cylinder?
    Mansfield,MA
    I noticed there has been no response...... I guess I would give Galfer a call. Beyond that, maybe check the length of the Galfer replacement and see how it compares with what is now on the bike.
    Good luck.
    Mod Squad
    2009 F800GS 1994 TW200
    I am not sure what the "pipe" is. The parts fiche shows lines with banjo connections directly to the master cylinder and caliper.
    CAL0987
    Oct 2010
    Pahrump NV
    Nov 2011
    Central Ohio
    If the new hose is long enough to reach, I'd eliminate the metal pipe. You might need to route it a bit differently, or a cable tie or two, to keep the hose out of harms way. The metal pipe probably let BMW use sharper curves than a thick rubber hose while still being less expensive than a stainless braided hose.
    Larry
    2006 R1200RT
    CAL0987
    Oct 2010
    Pahrump NV
    Got the old line out and the new line in, yes the full braided SS hose replaces the part metal, part rubber old hose... all worked out ok and I now have working rear brake!
    Mansfield,MA
    Quote Originally Posted by cal0987 View Post
    Thanks for letting us know!
    Information like this helps others tackling this job.
    Mod Squad
  1. '00 F650 Funduro gas tank
    By nvbeav in forum Thumpers - F & G bikes
    Last Post: 09-04-2019, 03:15 PM
  2. 2000 F650 Funduro
    By mrmayhem in forum Thumpers - F & G bikes
    Last Post: 08-04-2019, 07:15 PM
