Results 1 to 2 of 2
Thread: R65 Real differential seal
    Registered User 10drum's Avatar
    Jan 2016
    Southern illinois
    Looks like the seal, that seals on the shoulder of rear wheel is leaking on this R65. From what I can tell, looking at the part fishe, that's about the only place inside the wheel that would leak. Do I need to pull the spline to replace the seal?
    I spoke too soon. The leak is around the brake lever shaft.
    I tried to delete this thread,
    Thanks for reading it anyway.
    Liaison 20774's Avatar
    The first post can't be deleted by the OP. But we can leave this up. It might give others something to consider when investigating leaks and to consider looking around.
    Glad you tracked it down to the brake lever...I think the other seal takes some special tools and approaches.
  1. rear differential seal
    By brant914 in forum Airheads
    Last Post: 02-12-2020, 02:53 PM
  2. Replies: 26
    Last Post: 05-15-2015, 06:18 PM
  3. The real road to Real de Catorce
    By michaellmcc in forum Off the Beaten Path
    Last Post: 04-21-2015, 10:32 AM
  4. R90/6 with 32/10 differential
    By dfleming252 in forum Airheads
    Last Post: 06-13-2010, 11:26 PM
  5. Oil for differential?
    By drummer in forum Oilheads
    Last Post: 07-13-2007, 03:05 AM
