Results 1 to 4 of 4
Thread: Oil drip, 88 R100GS
    Oil drip, 88 R100GS
    I just bought a 1988 R100 GS with 60,000 miles. I'm getting a little drip of oil on the floor right below the head/cylinder joint on the right side. Is this likely pushrod seals or bad head gasket?
    Registered User 6322's Avatar
    Mar 2012
    Riggins, ID
    Either a head gasket or valve cover gasket. If it was a pushrod tube seal, it would be near the cylinder base on the engine block.
    Gary Phillips - #6322
    '77 R100/7 Dirt Hack, '83 R80ST, '85 K100RS w/EML, '93 K1100LT, '00 R1100RS
    BMWMOA #24809 jhall's Avatar
    Aug 2020
    Kentucky
    Hopefully Not Stripped Cylinder Stud
    Agree, likely head gasket, rocker cover gasket, or possibly just in need of cylinder head re-torque. I'd first try re-torquing, but use an accurate torque wrench, and be very careful not to strip the threads; the mono shock Airhead studs tend to strip in the aluminum block. For that reason, torque specs have been lowered, and re-torque occasions have been changed. Check your Owners Manual for specifics. Also, lotsa good info on the internet on the problem, as this is not new info, and several BMW gurus have written about it.
    I was lucky with the 95 RT, which seeped from both head gaskets soon after I bought it. I first simply re-torqued, but one side leaked again. So, for that side, I backed each bolt off 1/4 turn, then re-torqued. That was about 5000 miles ago and, so far, both remain dry (knock wood).
    Too lazy to go dig up my Owners Manual, but pretty sure max torque is now 24 ft lbs, whereas it used to be a bit higher. Also, no longer recommended to re-torque periodically, only when disassembling or to address seepage.
    BMWMOA #24809
    Registered User STEVENRANKIN's Avatar
    Spencerport, NY
    Center stud
    I have seen the center valve cover stud get over tightened and stripped out causing just such a leak. St.
  1. CLC gas drip?
    By miairhead in forum Oilheads
    Last Post: 12-15-2012, 06:00 PM
  2. /2 carb drip
    By chwood4 in forum Vintage
    Last Post: 09-03-2011, 03:09 PM
  3. fuel drip
    By LRISEN68502 in forum Oilheads
    Last Post: 04-07-2011, 01:50 AM
  4. Gas Drip
    By 72803 in forum Oilheads
    Last Post: 04-02-2010, 01:04 PM
  5. Drip drip drip.....
    By xp8103 in forum Flying Brick K-bikes
    Last Post: 05-01-2008, 01:34 PM
