Results 1 to 11 of 11
Thread: Neutral light slow to respond
    Bike will not start until neutral light appears, which sometimes takes a very long time.
    Registered User jsouth's Avatar
    Apr 2015
    Weatherford, OK
    I'm no help on the neutral switch issue (haven't had it) but you should be able to pull in the clutch lever and start it.
    2000 BMW R1100RS | Past bikes: 97 Suzuki GS500E, 82 Suzuki GS1100E, 07 Suzuki V-Strom 650
    Liaison 20774's Avatar
    Welcome to the forum! I'd check the grounds to the wiring. Get a good circuit diagram and find the sensor and clean the contacts.
    Mansfield,MA
    When I see this I would sit on the bike and run it through first/neutral a couple of dozen times and see if the next attempt works as it should. Not sure of the configuration on that bike but it’s frequently a pressure ball that has gummed up.
    There are some really good Oilhead mechanics here on the forum that may be able to give you more in-depth advice.
    And- Welcome to the forum!
    Gary
    Mod Squad
    2009 F800GS 1994 TW200
    Sluggish or no neutral switch actuation is a known issue with Oilheads. It is generally caused by a little bit of oil seeping into the switch body, causing oily contacts. Sometimes it just takes a few minutes of sitting to restore contact and sometimes shifting into and out of neutral wipes some oil off the contacts. The real cure is to replace the switch located at the back of the transmission.
    That said, the bikes still should start by pulling in the clutch, even if in gear. On the 1100s the sidestand also needs to be up - at least that is true of the R1100RS models and I think but am not positive of the RTs.
    If you have a wonky neutral switch and the clutch switch should fail you are more or less dead where parked. There are some cut-and-twist wires work arounds but they are a last resort.
    I had this issue with my 2000 R1100RS. I was not able to start the bike by pulling in the clutch lever, would only start if the neutral light illuminated.
    Before I replaced the switch, I notice that if I clicked, first to second a few times, it eventually would illuminate.
    Big job to replace the switch. I had clutch done at the same time.
    Quote Originally Posted by scooter View Post
    2000 R1100 RS
    2009 Jaguar XK
    Gerard jagarra's Avatar
    Aug 2016
    Reno, NV
    My 1100RS exhibited the same issue, it got considerable better when I switched to a synthetic 75-90 oil like Motul brand.
    1994 R1100RS-(5/93)-,1974 R90/6 built 9/73,--1964 Triumph T100--1986 Honda XL600R
    Feb 2005
    Trinity, NC
    .... The real cure is to replace the switch located at the back of the transmission.
    As Paul said, the lazy Neutral light switch is a known problem with the Oilheads. The original poster's problem is compounded by what sounds like a second problem - a failed clutch safety switch. To the OP: The clutch safety switch is MUCH easier to replace. Put in a new switch and you will be able to start the bike by pulling in the clutch lever. I find that if I work the shift lever up and down while still in Neutral, I can usually get the N light to light up.
    Yes, Paul, the standard 1100RT setup includes the side stand safety switch - the side stand is wired into the Kill switch circuit. The bike will not start or stay running with the side stand down. There are modifications to allow the bike to run in neutral with the stand down.
    Michael Stock, Trinity, NC
    R1100RT, R100, R60/6
    Registered User dieselyoda's Avatar
    Mar 2013
    Winnipeg, MB, Canada
    Mine was lazy for a number of years because I was too lazy to change it.
    Then there was the dreaded waterfall as when you take one thing apart, and another then another, you are changing more than just a switch.
    I sprayed brak-clean up in the cavity and pressure washed it a couple times a year and it was tolerable to live with.
    I changed it this winter. What else am I going to do? No hockey, the Covid, no friends over, way too much snow and freakazoid cold outside.
    Took me several months and I would like to point out that I am a pro-wrench with every tool you could imagine.
    If I had any ambition, I could have replaced it in less than afternoon with basic hand tools.
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    “The major civilizing force in the world is not religion, it is sex.”
    Feb 2005
    Trinity, NC
    Quote Originally Posted by dieselyoda View Post
    If you get that ambition, there are lots of Oilhead owners who would like to see that video.
    +1
    Quote Originally Posted by m_stock10506 View Post
    2000 R1100 RS
    2009 Jaguar XK
  1. Slow cranking and ABS light blinking problem
    By jconway607 in forum Oilheads
    Last Post: 04-03-2019, 09:36 AM
  2. K1600 GT Issues-running hot, throttle slow to respond, passenger backrest
    By slider14 in forum Straight 6 K1600 GT/GTL/B
    Last Post: 03-04-2019, 02:33 PM
  3. No Neutral light
    By blkb1rd in forum Hexheads/Camheads
    Last Post: 03-10-2018, 12:29 PM
  4. Neutral Light
    By mfifer in forum Oilheads
    Last Post: 08-21-2014, 12:09 AM
  5. R90/6 Neutral Light
    By dasBiker in forum Airheads
    Last Post: 12-01-2003, 05:17 PM
