2 Attachment(s)
Double wind screen with air capture...
The windscreen that came with your bike is a double windscreen with air capture.
When set up correctly, these essentially eliminate wind noise and buffeting.
Air is captured by the large leading screen as it protrudes out over the headlight.
[ATTACH]77024[/ATTACH]
It is then channeled up along the trailing/backside of the leading screen by a smaller trailing screen.
[ATTACH]77025[/ATTACH]
This design reduces or eliminates negative trailing pressure behind the windscreens.
And keeps direct airflow off of the rider.
It thus reduces or eliminates wind noise and buffeting on the rider.
MadStad has a line of screens with similar aerodynamics but these also have attitude adjustment mechanisms to achieve optimal windscreen angle ([url]https://madstad.com/[/url]).
Unfortunately, they don't have a kit for the K12RSs.
