Scarletswirl
Noobie question. Does changing the oil require disassembling the fairing to get to the filter? If so, is there an easy way to do it? (I'll take a less difficult too...)
On my twin-shock '84 RT, it's much easier to access the rear-most oil filter cover bolt if the right side lower is removed. The access issues may be different (perhaps better) on your monoshock RT, which has a different exhaust pipe layout.
Agree, on a twin shock. On my 78 RS I loosened the exhaust nuts, loosened the muffler clamps, and slid the exhaust forward to gain access to the thermostat housing. On my 95 RT, this was not necessary. The use of a ball tip Allen wrench helps though.
Wayne
I just love engineering where in order to do a proper oil change you need to move the exhaust. It reminds me of the oil change instructions for my F650. reading the factory repair manual, the first step is "Remove left front turn signal."
