97 K1100LT Master cyl locks when brake is applied
zabeathome
When front brake is applied master cyl locks and releases only releases when a brake line fitting is cracked
Blue Buddy
Buddy,
That is usually a sign of a failed rubber brake line or the piston in the master cylinder not returning enough to clear the bleedback port. Is this a symptom that has just started or did you just do some work on your bike?
I'm going to leave your post here for a day or two (or until I know you've seen this), then I'm going to move your post to it's own thread where it will get more attention.
:dance:dance:dance
Mr. Lee,
The rubber brake line was replaced with a stainless steel one. At that time the brake fluid was replaced silicon brake fluid.
When the work was done 3 years ago the brakes worked fine. Two years ago they worked. Since then the bike has been in storage.
When taken out of storage this July the problem started. No other work was done on the brakes.
Blue Buddy
Buddy,
Did you replace BOTH front brake hoses? The one from the master that goes under the tank to the modulator AND the one that goes from the modulator to the calipers?
:dance:dance:dance
