High Miles Preventive Maintenance
My '03 K1200GT just passed 180,000 miles and runs fine. Just wondering if there are preventive maintenance steps/parts replacement that should be done to prevent future problems--maybe a timing chain or some similar moving part? Drive shaft was replaced at about 108,000 and clutch and main seal maybe 10,000 thereafter. Everything else is original equipment. Thanks.
Things to check on a high mileage brick...
Unless it has been replaced, the clutch o-ring is probably shot and is leaking engine oil on the clutch.
This requires dropping the rear off the bike with all the "stuff" in between.
The engine will have to be "tilted" in the frame in order to get the trans off without dinging it up.
The tube from the crankcase breather on top of the engine that feeds engine oil vapors to the throttle bodies rots out in about 10 years. When was it last replaced?
Rear drive pivot pins probably need replacing. They tend to go every 20-30,000 miles.
Wheel bearing need to be inspected.
Brake lines and pads with a real good cleaning of the calipers.
Valve check with new plugs.
And...
Deryle & Wanda Mehrten
Sierra Vista, AZ USA
