Dyna III control module mounting.
toooldtocare
Active member
San Jose BMW installed a Dyna III (dual plug) ignition on my bike (78R100RS) in 1985. So far it has been running fine, although it has only covered about 12K miles since then.
They mounted the main control under the top engine cover by strapping it to the starter motor with two zip ties. Today, I decided to move it to a cooler location. First thing I found was one of the cable ties had broken and the unit was loose, but no damage was done. The second thing was a pinched wire, almost to the point of shorting out.
I moved the unit to the outside of the engine and strapped it to the top frame tube at the rear of the gas tank. It is all the way back just under where the tube splits into a ÔÇ£YÔÇØ. I like it there, but I could not find a proper way to secure it to the frame, so I just zip tied it again with a figure ÔÇ£8ÔÇØ on the ties. I would like to use hose clamps, but with the ÔÇ£YÔÇØ, they will not fit.
For those that have also installed the Dyna III, have you found a better location and method of securing it?
Thanks, Wayne
Dyna III Module
My module is mounted to the front of the frame downtube, as high as it will fit so it is pretty much out of sight, but still in the airstream for good cooling. The back of the module is a hollow half-round which fits on the frame tube and it is secured by a gear clamp that has each end bolted to the module body, all OEM arrangement.
My /7 has a cross member just below and behind the lower triple. That's where I have my module mounted.
My R75/6 came with a Dyna III mounted to the frame stub aft of the "Y". So it would not interfere with the toolbox, the hose clamp was moved from the center to one end of the Dyna unit. This way the Dyna box sits farther forward. When I replaced the unit with a booster and points, I made the same mod and mounted the new unit in the same place after failing to find another satisfactory location.
Thanks for the replies. I think I will leave it at the "Y" and get a hose clamp that will fit near the rear, and leave the zip ties at the front. It seems to work well there and is close to the coils.
Pictures
Here is a shot of the mod. The original holes are visible in the middle. The hose clamp, original to the unit, is attached with screws and Nyloc nuts.
Just so...works fine
Thanks again, I think I am going to modify mine like Stanley did. Right now the zip ties do not feel too secure.
Wayne
