'03 650 CS Turn Signal Issue
bhempel63
All stock, no farkle / bling
Switch on for right turn: both front / rear turn lights flash normal and normal flash from indicator at instrument cluster.
Switch on for left turn : both front / rear on BOTH sides flash normal speed but no indicator flash at instrument cluster.
Removed lamps from right signals, still no indicator at cluster and obviously no right signals flashing.
I have not disconnected right side wire at switch yet or at connector behind triple tree but will try this tomorrow.
Any thoughts????? Bad switch?
Buzz ( Lightyear )
Diode value
Anyone know the specs / ratings for these diodes? They are the gray plastic housed units. Current OEM list price is $45 & change
Diode / Turn Signal
Original diode is a “BYV27-200” rated at 200V -2A
Found one rated just over @ local brick & mortar retail for under $2.00
Many online for pennies.
Now to go ride....
