Help resetting trip meter
1hpyrider
Need help resetting the trip meter on my 2018 R 1200 GSA. I can't figure this out and my rider's manual is no help. Thank you and ride safe.:wave
Just so that people don't totally freak out, I'm going to add some context to your thread title. Might help with some searching as well. :wave
One 'splaination-
To reset the trip menu down twice to the motorcycle picture and scroll right to "onboard computer" then menu down once then scroll down to "reset individual values" then scroll right then scroll down to "current" and scroll right once more to reset it. BMW designed it to be easy.
On the F800GS, to remember which button it was, I painted it Hot Pink. Probably bad for the 'puter screen.
Assuming your 2018 is like my 2017..... which tripmeter are you talking about ; there are five. All five are viewed on the Nav VI, only three are visible on the dash display. The GPS has an A and a B trip that can only be viewed and reset on the GPS. The motorcycle also has a Trip 1, Trip 2 and Trip Automatic. The automatic meter resets on its own. Trip 1 and Trip 2 can be reset using the Trip button on the left side handlebar switch cluster. Scroll thru the menu using the trip button until you get to Trip 1 or 2. Once on the appropriate tripmeter press and hold the button until it zeros. This is all covered in my owner’s manual I believe.
To zero the Trip A and B meters on the GPS go to the Trip Data screen (you will have to search for this screen in the menu. You can put a shortcut button on your navigation screen) and depress the menu icon in the upper left corner. Then select the reset option.
I’m doing this from memory and under the aforementioned assumption.
I don't have a GPS. On the top of my screen is trip 1 and trip 2. I don't have a trip button on the left handlebar switch cluster. Our bikes must be a little different.
Turn bike on (must be stationary)
Press [Menu] button
Keep pressing menu button until "Trip 1" is displayed
Push selector wheel to the right (wait)
Trip meter will zero out
Scroll down if you want to repeat process for "Trip 2"
Regards,
A.
Press [Menu] button
Regards,
A.
Just went out to the bike and followed your directions. Nothing! There must be some additional steps I'm missing. Here is what I tried:
turned the bike on
pressed the menu button to settings
scrolled down to display
scrolled down to trip 1
pushed the selector wheel to the right and trip 1 turned off. I turned it back on and the same miles displayed before where there.
Any ideas?
Thanks for your help.
turned the bike on
Any ideas?
You have to HOLD the wonderwheel to the right until it resets. Takes a few seconds, it's not instantaneous.
Do you have the TFT dash?
Off the top of my head, with TFT..
Press the “down” button on the left control cluster. The two position switch that allows you to navigate the TFT.
Select My Vehicle and press the down button again.
Now use the wonderwheel and push it to the right until you get to onboard computer. Press the down button again. Scroll down to reset all values and press and hold the wonder wheel to the right. Tripmeter resets.
You can press right on the wonder wheel one more time and get to another trip meter. Same reset instructions, press down, and then scroll to reset and hold the wonder wheel right to reset.
The user interface for the TFT isn’t initially intuitive, but once you “get” it, it isn’t bad.
Did you get an owner's manual with the bike? If so, what does ot say to do?
I've looked, looked, and looked through my owner's manual and could locate nothing that specifically shows how to reset the trip meter. The way my brain works, I need specific step by step instructions. I know it is in the manual, I'm still looking. Thank you.:confused:
Check page 82 in your manual and see if that helps.
Onboard computer
Calling up the onboard
computer
Call up menu My vehicle.
page
82
Operation
Scroll to the right until the
ONBOARD COMPUTER menu
screen is displayed.
Resetting the onboard
computer
Calling up the onboard computer
( 82).
Press MENU rocker button
down.
Select Reset all values or
Reset individual values
and confirm.
The following values can be individually
reset:
Break
Journey
Current
Ø Speed
Ø Consump.
Calling up the travel
onboard computer
( 82).
TRIP COMPUTER menu screen
is displayed.
Resetting the travel
onboard computer
Calling up the travel onboard
computer ( 83)
down.
Select Automatic reset or
Reset everything and confirm.
Onboard computer
computer
page
82
Operation
computer
( 82).
down.
and confirm.
reset:
Break
Journey
Current
Ø Speed
Ø Consump.
onboard computer
( 82).
is displayed.
onboard computer
computer ( 83)
down.
Thank you Lee. I got both trip 1 and 2 reset to 0. Your instructions were spot on. Thanks again. :dance
