Need help on R50/5 charging issue
ron1200rt
I just bough an R50/5. It starts and runs well. But when lights and turn signal is engaged while riding it drains the battery so quickly!!
But when riding with NO lights and turn signal battery is fine.
I presume there is a problem with the charging system (dont know which part and what's causing this). What would be the cause of this problem? Any help is greatly appreciated...
For starters Check with a voltage meter the amount of voltage to the battery when running . Lights off then on and compare . The problem could be a relay or brushes, be sure to have a good ground and check other related wires. Can't hurt to go to Snowbum's site for more detail.
Nice Bike BTW !
1) When you insert the "key" and push it all the way down, does the red generator warning light come on? Location 3 below
2) And does it go out when the engine is running?
3) Do you know, reliably, how old the battery is?
Ditto what Peter said. I always liked that color: Federweise, I think?
1.) when key is inserted and pushed all the way down, the generator warning lights is "NOT ON"
2.) NO light when engine is running
3.) I just bought a new Yuasa battery.
QUESTION:
1.) What would be the possible cause of this issue? and what parts is involved? and how to test the parts if defective...i.e. diode, voltage regulator, rotor, stator..etc?
2.) How big is this job/repair in scale of 1 - 10?
BTW thanks for complimenting the bike. I really like the color of it...
Regards,
As Lew was pointing out, that red light is pretty critical. It's actually part of the charging circuit...the book from Motorrad Elektrik shows that. If it's burned out, then current from the battery is not getting to the windings of the alternator to start the electro-magnet. Without that, you won't get any charging.
Seems like the first thing you need to do is get into the headlight and carefully retrieve the bulb and check it...possibly all that needs to be done is replace it.
Down the road, if you're interested, there is an electrical mod that can be done to insert a resistor in the wiring harness which will allow for charging even if the bulb is burned out. That's really for a situation on the road so you can still get home, because you really do want to see the light and get feedback from it.
I'd say it's a 2/3 out of 10 type of job...depends on the general skill set. But be sure and ask questions about getting things apart as the /5s might have a few tricky steps. And if you're not getting charging (have you started it and measured the voltage at the battery...it should rise to near 14v at say 3500 RPM), the more you ride it, you will be pulling the battery down and eventually get stuck and/or possibly ruin the battery.
Let us know what you find out.
Thanks for the reply...
So if it's just the red charging bulb, can this be repalced? or do I have to buy a complete headlight assembley? I hope buld can be replaced...thanks again
The circuit is battery to ignition to kill switch to bulb to voltage regulator to 12v+ (hot) alternator brush to rotor through rotor to ground brush to ground. Usually the problem is not the bulb. Usually the problem is either severely worn brushes or an open circuit (broken wire) in the windings of the rotor.
Yes - the bulb can be replaced if necessary. But first use the bike's built in circuit tester.
Disconnect the negative (ground) battery cable.
Remove the front cover from the engine.
Hook the battery ground cable back up.
Identify the two wires to the brushes on the alternator.
Brown is ground - the other wire is +12v
Key on (pushed down)
Kill switch on.
Unplug the +12v wire and ground it against the engine block.
Did the light come on? If so you have confirmed a brush or rotor failure.
So glad I joined BMW MOA forum....you GUYS are the best and a great source of knowledge..
I will follow the procedures and will post an update.
Till my next post...
Ron
Kill switch on. ...
Just so you don't fret about it, there is no "kill switch" on the /5. This won't affect Paul's procedure.
What you will see when you remove the headlight. This is a later /5 equipped with fuses (black cylindrical shapes with green wire @ 4:00 position).
Depending on your build date, your bike may not have them.
Below: What you will see when you get passed all the spaghetti.
The bulb holders are a friction fit; just pull on then. A slight twisting action might be needed.
If you ever need to remove the instrument, the two tall "nuts" are removed, the crossbar is removed, and the instrument is free to come out from the top.
Kill switch on.
Hi Paul....yet another question, when you say "ground it against the engine block"....what I understand is to tap the red +12v wire to the engine block? Am I correct? I just wanted to make sure. Sorry for this dumb questions as this is really new to me and my first old bmw R50 bike...thanks again.
Yes - touch it to a clean metal spot on the block. From the end of that wire the normal flow is through the hot brush, through the rotor, through the ground brush to ground. Touching the wire on the block to ground it just bypasses the brushes and the rotor. It thus tests the whole circuit upstream to the battery.
I got it...now I am about to remove the front engine cover but do have another newbie question....can front cover be remove without removing the gas tank? or its a must to remove the gas tank before I can remove front engine cover??
Make sure you disconnect the battery before removing the front cover. There are connections under there that carry juice, and can easily short to ground when the cover comes off. Doing so does Bad Things.
Per instructions above.. I just need to disconnect the ground baterry cable...and the positive should remain connected correct? Also should I remove the gas tank to be able to remove the front engine cover??
Ok - here is that issue. It is possible to snag or brush the front cover against the diode board which has a hot wire directly to the battery when removing the cover. So disconnect the ground wire. Now there is no continuity back to the battery so the cover can be safely removed.
Then take off the cover.
But then - to do the test the battery has to be hooked back up - so hook the ground wire back up.
Always do the ground wire first even if taking both loose. Basic electrical safety. If the ground is hooked up and you are wrenching on the hot side, one slip with the wrench or a screwdriver to ground and you have a welder in your hand.
You don't need to remove the tank to remove the front cover. Take out the three bolts. Move the cover forward as far as you can and then down and out. The frame and fender will seem like they are in the way but they are not really. The horn might be.
I find it less of a hassle to remove the horn as well. A little more effort (one more bolt), but a bit more clearance.
Photo Credit: Brook Reams
