110 or 120 rear tire on a R75/5?
j_withers
Forgive me if this has been discussed before...
But i have two local mechanics that both gave me a thumbs up on my tire choice (Battleaxe BT45) but they have different opinions on sizing.
One says go with a 110 rear and and a 100/80 front.
The other says 120 rear and 100/90 front.
I've always thought that wider would be better (more surface contact) but it seems that many 'purists' say that the bike was designed with the thinner tires in mind and they are better for our old airheads.
I'd love to know if skinny is actually better and why? Or is it just a matter of opinion?
The bike is going to be a dry street only, cafe style R75/5. The bike is currently being built but it is time to mount some rubber on the rims. I'll want tires that will compliment the cafe/street fighter/ canyon carver riding style.
I have the wider sets on my current bikes but I don't know any different.
-J
I'd be cautious about a 100 in front...it might not clear the fender brace. A 120 on the rear is going to be a real bear to get on/off past the shock mount and brake housing. Remember the front was designed for a 3.25 inch and a 4.0 inch tire...you do the math for metric. Plus, just because someone says a tire is 100/110/120 metric doesn't really mean it will be those actual sizes...they vary between manufacturer.
fatter is not necessarily better. yeah, more potential tire to road traction, but they will also be more resistant to turning. and, as Kurt pointed out- since the rims (and swingarm) were designed to handle inch size tires, any metric tire will be a bit of a compromise. if you decide to go metric instead of 3.25" and 4.00" (yes, they are available), then get closest to original size that you can. that would not be a 120 rear, and probably not a 100 front.
I've been there with different tire 'actual' widths.
For example, a spitfire S11 120 is actually wider then a BT45 120 tire. I found our real quick when it was rubbing the swingarm and not spinning freely.
And usually i have to let the air out of the tire to squeeze it past the brake shoes and then inflate it when it is seated properly.
I currently have 100's on the front of both of my bikes and there are no issues. It is a tight clearance when mounting a fender with the tire on though.
Out of curiosity, who sells non-metric tires? All i can find are metric sizes in the Avon, Bridgestone brands. I'm not going to bother with Metzlers for this bike.
As a matter of fact Avon sells inch-sized tires...the RoadRider series. I have a Michelin Pilot Activ (inch-sized) on the front of my /7. There are other off-brands that sell retro looking tires for the vintage crowd...I have some IRC tires on my R69S. Lots of people sell non-metric tires.
I just ordered for my R75\5
Continental Twins-Classic Tires
Tire Size: 3.25H19 Front
Tire Size: 4.00H18 Rear
Actually cafe' bikes
I was always of the belief that Cafe' or canyon carver bikes of vintage design were supposed to have the same width tire and if possible the same diameter tire front and rear. I understand that it makes for a quicker handling and leaning of the bike. Its just something that I heard out and about but there is some logic to it as many European only bikes of that time have the same width tire front and rear
Another interesting thing I have found are there are more than just a few /5 rear rims out there that are the same narrow width as the front rim. I'm told by a few so called gurus that those narrow rear rims were for early /5 and very rare. I have one on my two owner 701/2 and one on may three owner 9,000 mile 73 /5. So just how rare are they?
Anybody out there know anything about that or why BMW would put such a narrow rear rim on a bike that should have a 400 tire mounted on it.
I would love to find a 350 / 19 for the front and a 350 / 18 for the rear that would be a nice vintage look matching set for both bikes. Has anybody got a source for those tires.
I've been real curious about those tires since i read the article on them. What is the tread pattern like? Do you have any photos?
you need to look at the evolution of tire construction. rim sizes have always been dictated by available tier sizes. when a manufacturer produces a new size rim (think Ducati Diavel), they need to ensure that at least one company is making a tire that will work on it. for vintage bikes, manufacturers built rims to fit existing prevalent tire sizes, not the other way around. (thus, the answer to your question about why Euro bikes all seemed to run on same size tires during a given period of time). Over the years, tires have consistently gained size. most of that was due to advances in tire technology, with some due to advances in suspension and frame technology. look at bikes from the 20's, 30's and 40's. tires looked more like modern bicy tires than modern m/c tires.
same sizing fornt and rear had nothing at all to do with better handling- it was about what tires were available, what could be manufactured efficiently, and what could be used across an entire product line. the speialization that we see today in motorcycling, to include tire sizing and construction, is a very recent development. for example: a 1950's or early 60's era H-D ran the same size tire as a VW Beetle, and wheels could be swapped front and rear.
Your bike doesn't make enough power to justify a wide rear tire. Superbikes have wide rear tires so the rider can apply power while still leaned over at angles your bike will never attain. Early application of power, given sufficient traction, improves lap times and overall race results. If you are not spinning the rear tire under power when leaned over, your tire is sufficiently wide as it is.
82 rs
I have 3 weeks on Avon INCH sized tires, both front and rear. These originally specified size tires don't look small or wimpy, but fill up the space nicely. They look good but handle better than they look
They're on Continental's website, of course.
The front tire follows rains grooves really badly.
Continental Tires
My experience with Continentals is that they weather check very rapidly during the life of the tire. I've read reviews noting this about their bicycle tires as well.
Reminds me of old R bikes where you could practically watch the various little rubber parts decay before your eyes. Their engineers need to spend a week in LA in August to see what their products face in terms of heat and air pollution outside the climate of der Vaterland.
years back I wanted to get as much ground contact as I could for my 1978 R80/7
so I ran a 120 on the rear. regardless of the issues of mounting and dismount in the frame ( on the rim) I discovered another intersting tidbit.
I then bought a 85r80rt and on the back of that put the same tire, a 120 metzler
then when the bikes were side by side I noticed that the 120 on the 80/7 looked smaller than that on the Rt.
sure enough, pulling out a micrometer, the tire on the 80/7 was so curled to fit into the narrowewr rim, it actually made the ground contact smaller than the same tire on a wider (RT) rim
so I dont think that going to a 120 on a norrow rim does any good
So based on this theory, a wide tire is just extra material or overkill?
Even though you are making road contact about the width of a credit card, I would think that an extra inch or so of contact could only help the bike's stability.
Compare those thin road-race bicycle tires to a thicker beach cruiser style tire. Of course they are meant for completely different styles of riding but I can say that a thin tire sure is squirrly.
I like the idea that the bike will turn better with thinner tires but will the bike become less stable or 'looser' as a result?
I know this bike will never reach superbike/crotch rocket leaning turns but it will have many performance upgrades (suspension, siebenrock piston kit, lots of weight reduction, etc) that will make this not your stock R75.
Not to mention that the bigger tire has more unsprung mass which is a component of handling and performance.
For those still interested in this topic, I'm having another look at the available BT45 sizes and it seems that the options are:
Front:
3.25-19 H
100/90-19 H or V
Rear
4.00-18 H
110/80-18 H
110/90-18 H
120/80-18 H
120/90-18 V
