yourpalcal
"I did notice a spark from an area of the choke cable that had worn to bare metal. It was sparking were it touched the gas lever. " That should not be happening. Do this: Follow and inspect the positive lead from the battery along the main frame to where it drops down to enter the engine housing just above and behind the diode board - actually through a 'u' shaped opening at the rear of the aluminum timing chain cover. Check to make sure that there is a rubber grommet surrounding the positive battery lead to isolate it from the engine through that opening. Next, make sure the grommet is intact and that the battery lead is not rubbing against the aluminum. Try the starter and watch closely around the starter solenoid where the battery lead terminates with a large ring connector on a large threaded pin at the back of the solenoid. If that connection is loose or in contact with the case or other connectors it will spark which equals a high resistance connection. It takes full battery voltage to activate the electromagnet which engages the starter gear and spins the starter motor. If someone replaced the starter recently, the routing, insulation and connections for the positive lead might be the problem.
You could be onto something here. I did notice some wear on the small red power lead wire near the connection to the battery. I may end up removing the plastic cover on the harness to fully inspect this wire. I replaced the engine wire harness but was hoping not to replace the chassis wire harness. Although I plan to keep this bike for a long time so it’s probably inevitable. I plan to do some more investigating this afternoon. Thanks for the tips!
