bombayduck
I have a 83 R100S that I'm still going through that I recently bought. When I got the bike, the rear brake wasn't working no matter how hard I stepped on the pedal. I could stand on it. Nothing. When i took the wheel off, the brake shoes and the drum were covered with thick black gunky grease. I mean not just a little but a whole load of grease. Like someone had taken some and coated every surface of the drum and shoes with a thick coat. I cleaned them up best as I could with paper towels and brake cleaner. The splines on the drive looked ok and just lightly lubed. I got a O ring to fit around the spline and slipped it in the recess behind the spline. I read somewhere that if the seal is leaking, that may fix it. Anyway, I put it all together and went for a ride. I then had about 50 Percent braking at the rear so I figure that the shoes are contaminated and lost gripping power. So after riding 500 miles, they seem still the same about 50 percent. (I had a R100 in the past so I know what the rear brake is supposed to feel like) I plan on getting new brake shoes soon. My question is where did all the grease come from? The rear drive shaft oil level is OK. I then checked the final drive oil level and the bolt was a little loose. Oil came out the hole when i removed it so I tightend up the bolt but it was stripped and wouldn't tighten. The PO had put a thick rubber washer there so as to make a better seal on the bolt (I'm guessing) So could the final drive gear oil have leaked out that hole, traveled down and seeped into the brake drum and then mixed with the brake dust and made a greasy mess? Or could that much oil/ grease leaked past the final drive spline seal? I would like to know before I put on new brake drums. Anyone with an idea? Thanks, Brad
