RDL system on 2020 R1250RT
wemi
My solution to the seat issue. Well made, very comfy. This is the "sport seat" version of the RDL seat. It's a bit narrower and does not have the extreme wings on the front seat, which I do not need. This is the All-Leather version with "brown bomber" seat inserts and black leather trim using the stock heater controls provided in your own seat pan, which you have to send to RDL The fitting small driver headrest with the same color combo and the passenger headrest on the top case are also included in my package. Total cost w/freight, insurance and CA taxes at $1,750.00 and three month wait.
Nice!
Report back on how your butt thanks you.
Jury still out re: my butt. The seat is quite firm compared to the OEM. so the inverse of the stock furniture applies. First half hour of the stock seat is more comfortable but then it becomes increasingly more uncomfortable. Longest stretch on the RDL has been around 8 hours with tank/bladder stops, of course. The driver's backrest is very nice (and extremely sturdy as opposed to the Sargent, which I also own) as it provides a more forward/straighter seating position due to the pressure in the small of the back, making the handlebars easier to access. Also the Ilium hwy pegs on my crashbars are within better reach and allow for a more solid backpush into the backrest providing significantly more control of the bike.
As I said before fit and finish are impeccable {stiching, underside fastening is up to BMW quality, material quality) making the ridiculous price of admission worth while.
YMMV
how much of a difference in the RDL seat height have you noticed compared to the OEM or Sargent? Were you able to flat foot previous to the RDL?
RDL will build the seat to your wishes after you send them some pictures of you on your bike in some specific positions. From this they can gage what the seat should look like for you. My stock seat was in the low position and my new seat has not moved from that. I can still "flatfoot" as before. That being said, the "winglets" on the edges of the seat will cause your legs to "NOT fall down" as before on your stock seat. By design your thighs will therefore be a bit higher on the bike. This is why I chose the Sport Seat. Its "winglets" are a bit narrower and IMO better suited for this bike.
On a previous K1600GTL, which I owned; I used the standard wider seat as that bike is wider than the RT. It was more of a "road sofa".
As I said in my above post, SFSG.
