So the diaphragm is bad in my right carb. 1975 R75/6, 69,516 miles. I've owned it since nearly new, and other than a diaphragm on the right in the very early 1980's, the carbs have never been apart.
I've got a step by step video on how to disassemble my exact carb that was made years ago by a couple of guys in San Diego, plus the videos on Youtube. I took it to a friend today. One of those guys in his mid-60's who started working on bikes and cars and everything else mechanical while he was still in the womb. I have yet to see something he can't fix. I just wanted him to look at it, but he took quite a bit of it apart, bit by bit, cleaned and reassembled, basically just seeing how good a shape it's in. Which is pretty good - it's not varnished or sludged up at all.
At any rate, looking at what two diaphragms would cost, it looks like I might as well get a rebuild kit. I need to decide whether to disassemble and soak in cleaner, or just clean it as I go with a spray can of carb cleaner. My friend is going to help me, so I'm not worried about getting in over my head. I'm sure not going to spend hundreds of dollars sending it to Bing.
Any input appreciated. I have no local dealer. I've used Capitol Cycle off and on for years. I use the Max on line fiche, but don't recall ever ordering from them. At any rate, the OH kit is 13 1 1 258 051, $73.64 at Max. Capitol has the same part number with an A after it, for $35.95. I assume that's after market. I have no problem with that, if the quality is good. For example, I buy Mahle oil filters, once I figured out they made them for BMW.
1. Anybody have experience with that kit from Capitol? If not, I'll default to the safe option and pay more for the BMW. I'm especially concerned about the quality of the diaphragms.
2. I'll probably call Bing Agency tomorrow and price their stuff as well. But research here and AdvRider suggests they're higher than BMW.
3. There are the original floats. I would guess most people say replace them, after 40 years. But I was getting acceptable mileage, and they were keeping the fuel level at about 20 mm in each carb. They're very slightly "above" parallel, but I don't want to mess with bending the tab when the bike was running great until that diaphragm went last weekend.
4. I am worried about the o-ring on the throttle shaft, just based on what I read. Is it a problem? I guess that is why I thinking about not taking it entirely apart and soaking in cleaner.
Thank you for any thoughts.
