Hi gang,
I have a 1980 stock R65 with a single disc ATE brake in the front. The ATE caliper looks nearly identical to a Brembo although it's silver instead of black. I discovered one of the two pistons leaking, so I purchased a complete rebuild kit and pistons from Boxer2valve. I replaced the two pistons after carefully cleaning the bores, and installed new seals and dust covers. The rebuild went great, no issues. Installed new brake pads and started the bleeding process. Prior to bleeding, I intentionally allowed all the old fluid to drain out the open flexible brake line that went to the caliper ( maybe a mistake?)
I started using the traditional pump the handle and crack the bleeder screw method dozens of times and got some air out, but the handle would always go through half it's travel before firming up. Then, I allowed it to gravity bleed through many refills of the master cylinder, same result.
So then, I purchased a vacuum bleeder though Harbor Freight that uses compressed air to create a vacuum ( It's a nice unit for $35 imho). It worked great at pulling fluid through at a slow enough rate that I could easily keep up with refilling the mc. The device has a latch on the trigger that allows you to keep the device on continually without having to continually hold it. My compressor was set at 120psi that results in moderate suction from the device.
So....after about 32oz of fluid going through the system, still no improvement. Handle goes halfway before firming up.
Weird observation: When initially pulling the brake handle, fluid will squirt straight up through one of the two holes at bottom of the mc (smaller diameter one I think) and WAY out of the mc (Think water fountain) if I pulled too rapidly. Made that mistake several times, fortunately didn't get on tank or fender, just some around base of mc that I cleaned off immediately.
For those not familiar with the R65, the routing of lines goes like this (in descending direction) Master Cylinder, short flexible line, short metal tube, Brass union block behind headlight, flexible line to caliper.
Alright Airhead Collective, can anyone help me figure out how to bleed this thing? Any input greatly appreciated!
Thanks, John Brusso (Mufflerbearing)
