My R1200RT '08 has 120,000 miles (mostly done via 80 mile round trips to work with 30% of this city driving and the rest freeway driving) - just recently purchased it - the clutch works fine - but I am guessing soon it will not - so planning on an eventual DIY clutch replacement project - have some questions:
1. Normally I wait for things to break - but I ride less in the winter here in the San Francisco area - so wondering if I should just change the clutch and be done with it. What would you do?
2. My BMW manual says that I need to put in a couple of screws on the left/right side and install a couple of threaded pins. as I separate the rear frame. What is the purpose of these pins and do I need to get special pins or is there an alternative?
3. After removing the clutch, thrust plate, and clutch housing I am to check for wear on rotating surfaces and for scoring. Is this going to be an obvious check - or do I need to get someone experienced in clutch repair to do this? Measuring clutch wear seems to be straightforward - this does not concern me. However, wear on other items is a judgement call and not sure how to proceed. My parts costs could range from $60 (knock-off plate only) to over $1000 and I do not wish to spend money 'just to be on the safe side'. What are the chances that I will need to replace other than just the clutch plate? And will I know by looking what other items really need be replaced?
4. Here is a link to a new $60 clutch plate. Anyone tried one of these?
http://www.ebay.com/itm/Clutch-Disc...Parts_Accessories&hash=item27d8fdeb56&vxp=mtr . I am OK going with a Chinese replacement unless someone has had a bad experience with them.
5. Is there a life expectancy associated with items in the clutch OTHER than the actual clutch plate?
My IDEAL goal would be to buy the clutch plate and then disassemble the clutch components and see what else I need to buy as BMW OEM parts - then proceed with final repair. Input is appreciated. Thanks.
