On the road here in W.Virginia heading to Michigan but finding neutral and getting clean shifts became harder and harder. I finally looked at it and the whole foot shift lever is extremely floppy, as in big movement from side to side. This is a R100S made in 1979 where they went to the new linkage rod with the rubber boot and the two spring clips inside. However, I had that come loose once before and that is not what is happening this time..
In this case the shift lever is going up and down like it should (1st to 2nd to 3rd, etc.), but it is loose laterally. You can actually shake it and it will move left to right. The toe rubber on the selector probably moves an inch or more side-to-side. Meanwhile, where the Allen bolt goes through the pivot point looks from the outside like it is missing a cap or maybe a nut or something. You can actually see the threads on the female mating surface to the Allen.
We cant figure out what's missing by looking at the exploded diagram of the microfiche (MAX BMW).
It doesn't appear to be getting any worse, but finding neutral, etc. is difficult.
Can anyone please help?
Thanks in advance,
Neal
Thanks in advance,
Neal
