Pull the head, have a machine shop do a weld buildup to replace the missing material including the threaded hole, and remachine the hole and do a very light skim cut on the mating surface.
It’s not a good candidate for in situ repair nor bodging up with epoxies and such as I’m sure someone will recommend.
Best,
DeVern
I was able to insert a helicoil and was able to tighten bolt to spec. fingers crossed.
tHANKS, The damage was most likely caused by overtightening.The capscrews that engage those holes are "shoulder bolts". Then snug to the shoulder and no tighter. They need to be snug enough to keep from falling out. That is their job. The valve cover simply rides on the compressed rubber retainers on each bolt and the rubber gasket(s). A Helicoil will hold here just fine. I have used them to repair this damage at least a half dozen times.
If the helicoil does not work, another attempt could be made with a time-sert. The helicoil is a coil of square cross section wire whereas the time-sert is a bushing the has threads on the inside and outside of the bush.
https://www.amazon.com/TIME-SERT-M6...keywords=time+serts+kit&qid=1655061950&sr=8-3
