My son has a 197?4 R75 frranken beemer that he rescued from the ARMA circuit and returned to street legal. it has been ridden off and on for the last 20 years with no problem. The amber oil light came on while cruising on the interstate. He shut it down immediately and we hauled it home. WE put a test oil gauge on it and it had oil pressure. We reinstalled the sender and the light comes back on. Some where he read that the light will come on if it over pressures. We now installed the oil gauge permanently. Cold pressure at rpm is 85 psi and higher. hot pressure at rpm is about 65-70. Idle pressure hot is 40 psi.
All the numbers seem a little high compared the the numbers in the specs. . It has 20-50 oil in it. The questions are: is there problem with over pressure? ( It is being ridden) Is there a reason for over pressure? Could there have been a modification to increase the oil pressure when it became a race bike?
PS the oil pressure sender is probably a VW sender bought at Auto zone years ago.
