CMGR1100RT
The TPMS readings from my 2016 R1200GS Adventure have become erratic subsequent to a recent tire change. I ride ~ 70% curvy north Georgia mountain roads, 20% highway, 10% secondary roads, 0% off road, 0% track. I ride aggressively. I have ~ 6,700 miles.
The first 6,500 miles were on OEM Michelin Anakee IIIs. I never had an issue with accuracy of TPMS. The TPMS would display values typically within +/- .5 PSI of the values I filled the tires to using a tire gauge. I have three tire gauges which give similar results. Above is true when the tires are cold and “temperature compensation” is unlikely to be a factor. The TPMS-displayed values have seemed reasonable for the whole 6,500 miles.
At 6,500 miles, the dealer replaced the Michelins with Metzeler Roadtec 01s. Immediately (i.e.: in the dealer’s parking lot), I noticed that my TPMS values are 3 – 4 PSI lower than those of my gauge, even when the tires are cold. The dealer says there’s not much they can do because: “they do that”, “3-4 PSI is within BMW spec”, “It is entirely normal for the display to indicate a different pressure from a gauge due to temperature compensation”, “height above sea level”, “TPMS is a pressure monitor, not intended to set tire pressure”, do not use TPMS to determine tire pressure – only use it to determine whether there is a catastrophic loss of air. Of course, I don’t disagree with any of these; however, I view them as excuses for not investigating and rectifying the issue, since all these were true before the Metzelers were installed when the TPMS worked just fine. In addition to the incorrect pressures displayed, the TPMS is very slow to update. The first updated pressure readout from the front occurs at ~ 5 miles, the rear updates only after ~ 10 miles.
Does anyone have a solution/path forward? I was told by one local dealer that they can recalibrate the TPMS sending units to the exact (determined by a tire pressure gauge) air pressure in the tires. However, the dealer who installed the Metzelers denies that that can be done. If I decide to go that route, I think I need to trailer to the dealer, so the air pressure can be set cold without “temperature compensation” factoring in. I’m pretty frustrated that a silly thing like this on an almost-new bike is wasting time better spent riding, but the local dealer prefers a do-nothing approach.
