roger 04 rt
Eleven, As I mentioned earlier, Super Tuning relies on a procedure in it called Zero=Zero, which has lately been shown to set the initial throttle stop too far open, leading to poor regulation with the BBS adjustments. The TPS final setting of 360-370mV is higher than BMW and the GS-911 call for.
The stop screw adjustment is only to correct someone else’s mis-adjust, why do you think yours require resetting?
If you believe adjusting the stop screws and TPS are necessary, the TPS final voltage at idle should be 340 mV (note that an idling engine will pull a worn butterfly more closed than it is a rest, changing the TPS setting).
If you must adjust the stop screws the Zero=250mV procedure (in the link from my earlier post) gives a better final result.
