Hi,
Someone at a local shop has told me i should convert from point to electronic ignition, and they want to sell me the Dyna III system. I'm hesitant, both because i think the Dyna III system has a steep price (almost 500 USD / 430 EUR with the Dyna green coil) and because i'm not sure it will provide any real improvements over the original ignition system - provided it's in order and set up properly.
Should i convert to electronic ignition? And if so, which system is best? The Boyer Bransden Micro digital seems trustworthy and relatively inexpensive (150 GBP), and there seems to be some advantages to the Omega-system, although it will end up costing about the same as the Dyna III system. Are there others? What would you recommend?
