Not long after I bought my 08 R1200RT I mounted a set of TrailTech 30W HIDs under the oil cooler using EzyMounts. These have now been removed and replaced by VisionX Solstice Prime SP120 LED lights that are about the same as the D2 round LEDs sold by Twisted Throttle. Both use Cree "10W" LED.
The link to to the VisionX lamp is
http://www.visionxusa.com/LED-Solstice_Prime_Series/c1_106/index.html
I removed the TrailTechs for several reasons but primary is their total lack of reliability. I have been through 2 generations of ballasts and 3 generations of lamp design and the bottom line is that they cannot be made adequately reliable for motorcycle use, primarily because the design (though a novel and interesting concept) cannot be executed adequately. The lamps either fail from vibration (even the latest version designed to be more resistant) or from moisture penetration (which is why they are supplied with translucent silicon covers) caused by heating/cooling creating a vacuum inside the lamp (which is not truly sealed like a sealed beam- it is simply a cemented indoor light bulb design with an HID capsule in the back of it). The TT's also, on my bike, didn't add all that much in the way of useful light, being essentially "swamped out" by the output of the two Hella FF50s using the 65 W Osram H-7 Rallye bulb. So having now blown about the 7th or 8th bulb (at $75@ though several were supplied under warranty by TT when bad ballasts blew the early ones), it was time to dump them. I do not recommend the TrailTechs, the identical PIAAs or the similarly designed Warn's in any wattage or style.
Having found that the addition of FF50s caused me to use the TrailTechs mostly as around town conspicuity lights, I decided to replace them with the best very compact conspicuity type made at present- the latest hi output ("10W") LEDs. (But note that there are multiple LED designs if you want to use a bigger lamp that wouldn't work on EzyMounts) There are both round and square versions available and I simply picked the highest output type - happens to be the VisionX version but could have been the D2. But the VisionX is sold as "lamps only" which is what I needed because my bike already had a very nice PIAA harness powering the TrailTechs and I neither wanted to pay for nor install a different one. I saved about $60 by simply using the existing harness by just cutting off the TrailTechs and splicing in the leads to the VisionX lamps.
The VisionX lamps run on anything from 9 - 50V DC and draw only 0.83A so there is in fact no need for a relay harness to provide full battery voltage at all times- they could be wired with almost any simple connection and a direct switch. I used the PIAA relay harness because it was already on the bike and changed its fuse to a suitable low amp rating (a good rule of thumb is to fuse at 2X the working current so a 4A or 5A fuse would be a good choice)
Physically, the VisionX is a bit shorter and narrower than the TT HID so clearance to the fender when it is hung pendant style on the EzyMount increases to be very similar to a PIAA 1100 halogen. For comparison, the photo below shows the VisionX on the left mount and the TT on the right.
The VisionX lamp can be wired with a dimmer- I chose not to add one at this time.
