barkleystuart
Barkley
I have a 1974 R90S, after letting it sit for some time 2 years, I went to clean it up and service it. I noticed that the front brake lever was completely soft. I took the tank off and found that the reservoir is empty. I removed the Master Cylinder and I have ordered a rebuild kit.
I noticed in one of the threads I found that there is reference to the O rings that seal the tank to the Master Cylinder do not come with the rebuild kit. Is that correct?
Thank you for any help you can provide.
